header coating flaking off
Old May 11, 2011 | 10:19 PM
mpower22's Avatar
mpower22
Default header coating flaking off
I can't remmeber the brand or the temp rating but I thought it was high enough. I'm only NA. Any chance the flaking material could get sucked into the engine and damage it? The headers are coated inside and out
Matt
Old May 11, 2011 | 10:30 PM
smurfkiller's Avatar
smurfkiller
no real worries about it going back in and hurting anything. that sucks id be pissed i have never seen any flake off. but i have only seen coatings from the major companies who do it. yours i assume has to be from a lesser quality coater.
Old May 12, 2011 | 05:47 AM
taken19's Avatar
taken19
Track Junky
The exhaust side should never see vacuum to pull anything into the engine. I would think your car will be fine. I would definitely call the coating company if you remember which one and see if they are willing to do anything for you.
Old May 12, 2011 | 08:50 AM
Stainless Works's Avatar
0Stainless Works
Former Vendor
Matt
That sucks! Are they steel or stainless steel headers, just curious...
Old May 12, 2011 | 11:47 AM
mpower22's Avatar
mpower22
Stainless Kooks. So even under a hard downshift and decel this stuff could not get sucked in?
Old May 12, 2011 | 12:11 PM
EDinPA's Avatar
EDinPA
Any cats? I would worry about filling them up first.
Old May 12, 2011 | 12:18 PM
0Stainless Works
Former Vendor
Good note on the cats! yeah something up with the coating,get it fixed!
Old May 12, 2011 | 12:36 PM
mpower22's Avatar
mpower22
yes I have cats, good point, I am worried about them getting clogged also.. I'm pissed I have to remove these....
Old May 12, 2011 | 04:21 PM
FNBADAZ06's Avatar
FNBADAZ06
I've heard several people comment that on stainless steel headers that coatings aren't really neccassary because of the insulating values of stainless over standard steel.
Is that true ?
Old May 12, 2011 | 05:40 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Is that true ?
Not really. Stainless has a lower heat conductivity than most other steels, but it is still very conductive compared to coatings.
Old May 12, 2011 | 05:54 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
If they are flaking on the outside, good chance that they are flaking on the inside and clogging your cats.
Old May 13, 2011 | 07:45 AM
0Stainless Works
Former Vendor
Is that true ?
The benefit of thermal coatings is the reduction of under hood temperature. Stainless Steel's main benefit is anti-corrosion. A coated set of headers made of a standard steel will rust. Coating or not, 304 will not corrode. Adding a high temp coating just adds to the already timeless appearance of high quality stainless steel.
Did you know you can clean our stainless steel with a scotchbrite pad?
Old May 13, 2011 | 01:41 PM
NORTY's Avatar
NORTY
Not using 316?
To header coating flaking off
