DRL problem
Old May 12, 2011 | 10:28 AM
1badassZ's Avatar
1badassZ
Default DRL problem
This is how my car looks after being at work for a couple of hours this morning. The taillights are also illuminated.
DRL's won't turn off. Went for a drive thinking it might just be a crazy glitch and it would reset after. No luck. Also noticed that when rotating the light switch forward to turn off DRL's, the green light in the instrument cluster that says the DRL's are on, doesn't turn off. I ended up pulling the relay under the hood just to shut off the lights.
Suggestions on what might be causing the problem?
Daytime Running Light sensor on dash?
E-Brake switch?
BCM?
Old May 12, 2011 | 10:34 AM
CGZO6's Avatar
CGZO6
The green light on the dash indicates the headlights are on. The other green light indicates the fogs are on. If under warranty, I'd take it to dealer, the BCM (body control module) is probably going bad.
make sure you don't have anything covering the light sensor on the dash.
Even if you turn the lights on manually, they should shut off after 15 minutes. If thier not, the BCM is probably malfunctioning.
Might be the DRL relays, but I don't see why the brake or running lights would be on as well.
Good luck,
Old May 12, 2011 | 11:11 AM
1badassZ's Avatar
1badassZ
Yeah, I was afraid it might be the BCM. ARRRRGGGGHHHHH! Anyone have any ideas on testing? Someone willing to loan me their 07 BCM?
Old May 12, 2011 | 11:25 AM
torquetube's Avatar
torquetube
There is no DRL indicator or headlight indicator. The green light indicates that the parking lights are on.
I'd start by checking for a short to ground on the BCM side of the park lamp relay.
Old May 12, 2011 | 12:53 PM
1badassZ's Avatar
1badassZ
Tested the DRL running light sensor on the dash by covering it up. The headlights came on, then I manually turned off all the lights, and the "Headlamps Suggested" message popped up. So I don't think it's the DRL sensor.
Also, by manually turning off all the lights, the "parking light" symbol on the cluster stays lit up and the parking lights are still on. Only way to turn them off is by pulling the relay.
Old May 12, 2011 | 01:10 PM
CandyRed77's Avatar
CandyRed77
Have you tried replacing the relay, might just be sticking in the ON-position? Would be easy to try with another relay from the box.
The other thing to check is whetehr the relay is clicking when you try to turn the lights off, at least you know which side of the relay the issue is.
Sonny
Old May 12, 2011 | 02:27 PM
1badassZ's Avatar
1badassZ
Yeah I swapped the relays and that didn't help.
Went by a friends at lunch and he was able to get them to turn off. He held the switch for turning the lights off back for 10-15 secs. Lights went off and never came back on. I had tried multiple times to switch them off from the same place, but didn't hold it nearly as long as he did.
Something weird is going on. I hate electrical gremlins.
Old May 12, 2011 | 03:30 PM
juyanith's Avatar
juyanith
I feel your pain, although my issue is slightly different. In my case the fog lights go on and off randomly. I have even seen only one side come on while the other stays off. I can still turn them off (for a while) using the switch though.
Good luck.
Old May 12, 2011 | 06:22 PM
vette6500's Avatar
vette6500
my taillights would stay on after a BCM replacement before.
had to take back to dealer and have them correct it somehow.
but not sure why yours would suddenly do it without the BCM ever being touched...
To DRL problem
