oil in the intake
Old May 18, 2011 | 12:14 PM
1Corvette's Avatar
1Corvette
"I have a question about hose routing for the catch can. I have my catch can in about the same place as 1Corvette - next to the battery. The hoses are each about 30 inches long, and snake around the fuse block, but they stay fairly level from the catch can to the connections at the engine.
Is it a problem to have the hoses that long?"
The answer is no. The longer the hoses, the more chance the oil will coalesce and collect in the can instead of being carried with the airflow into the manifold to be burned. The catch can being farther away from the engine gives the oil vapor more time to mix with water vapor (a product of combustion) and drop out in the can. Remember, not all of the product laying in your manifold or catch can is oil. Some may be motor oil vapor, some is condensation, some is combustion gas vapor that has dropped out. Farther from the engine is better. Feel the hoses after you have driven the car. One will be much warmer than the other.
I agree with FrankTank, may not really need it, but I don't like the oil being burned and therefore the catch can is a nice simple way for me to slow it down.
MikeSVT04, good question, but virtually every engine burns the vapor from the PCV to meet EPA standards. You just don't see it in other engines. I do remember reading somewhere in a post that GM calls for special motor oil in these engines with the GM4718 spec. (I believe this is the correct number) The reason is, other oils without this spec number may contaminate the catalytic converter. Now you know where the oil is coming from that "may" attack the cat.
Old May 18, 2011 | 12:19 PM
tomiboy's Avatar
tomiboy
At Spins suggestion I put one on as my first mod. Later I did headers, 160* T-stat, and intake with a tune. I just did a ported IM and TB at 8,500 miles and didn't find a drop. Elite Engineering.
Old May 18, 2011 | 12:50 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
we are introducing a catch can here shortly.. should be one of the most effective on the market
LS engine are infamous for this.. its blow by and should be controlled.. it will reduce the efficiency of the engine after a while
Old May 18, 2011 | 01:51 PM
glennhl's Avatar
glennhl
I ran mine over to the side, but not back to the battery for the same reasons you listed (try to find a cool area to help the oil to coalesce.
Could you post a photo of how you mounted your separator?
Old May 18, 2011 | 02:52 PM
HOXXOH's Avatar
HOXXOH
Long hoses to cool the vapor? Isn't that the same thing that naturally happens in the manifold before the oil reaches full operating temperature, such as happens on short trips? And aren't most Vettes lightly driven low mileage cars, therefore, being the most susceptible to oil contamination? The contamination is why GM says to change oil at least once a year. So apparently the choice is either drive the car enough to bring the oil temps up and burn off the contaminants or put in a catch can and manually drain small portions while waiting for the annual oil change.
Those "special" oil specs are industry wide. GM just issued their own to assure the EPA wouldn't single them out for not telling owners of the new requirements. You'll probably note that the latest GM spec is also in line with the latest oil industry and EPA requirements. You probably never noticed the change, as most things receive very little fanfare.
For more information about how the government regulations affect the oil industry and auto manufacturers and the specs you refer to, go here: http://www.nalube.com/news/gf4specs.htm
Just be aware the GF5 specs are the most current.
Old May 18, 2011 | 02:57 PM
MisterMidlifeCrisis's Avatar
MisterMidlifeCrisis
I took a piece of 1/2 inch wide plate steel with the holes in it every inch and bent it to fit (this is the plate steel that I used to mount my garage door openers). I mounted one end to the battery hold down bolt, and the other end to the mount provided with my catch can. My can sits just behind the fuse block, and the hoses around the fuse block and then across towards where they connect to the engine. Overall length of the hoses is maybe 25-30 inches each.
It's not great looking as the plate steel is silver colored, and it wobbles just a little bit, but it's good enough for now. I'll probably remove it and spray paint it one day.
Old May 18, 2011 | 03:06 PM
HOXXOH's Avatar
HOXXOH
No matter how effective a catch can is, it cannot control blow-by. That's what piston rings do.
Old May 18, 2011 | 03:27 PM
99blancoss's Avatar
099blancoss
Former Vendor
LOL, I guess its how I worded it, the oil being introduced into the intake is what I was inferring to being as needing to be controlled. Someone had asked where the oil comes from so I combined both answers
Old May 18, 2011 | 04:14 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Details?
Old May 18, 2011 | 06:49 PM
99blancoss's Avatar
099blancoss
Former Vendor
I hope to put one in a test car this week.. options are OEM color of your car or polished
design is dual chamber single can with a filter element and no its not a scotch pad or steel wool, can be complete cleaned and of course the bottom drain. There is another aspect to it that is hush hush for now ...LOL but should make a difference.. cost should be in the 120-140 range shipped, trying to keep it as low as possible ...the prototype is always more expensive
Old May 19, 2011 | 08:04 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Originally Posted by MikeSVT04
ok stupid question here....
why would GM design it this way? Meaning why would they make it so that oil goes back into the intake? Seems like a stupid design.
It's called PCV (positive crancase ventillation) and is required by emissions control regs. Crankcase receives fresh air from intake and discharges displaced crankcase vapors (with oil vapor) through the passenger side valve cover hose to the intake manifold for combustion burning. As a result, the intake manifold gets oil coated and the combustion chamber gets carbon buildup during combustion. Placing a catch can between the valve cover nipple and the intake manifold removes most oil while still maintaining the pcv. Leads to much less carbon buildup, minimum hot spots in combustion chamber, and therefore less possibility of pre-detonation knocking and pulled timng.
Old May 19, 2011 | 08:33 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Excuse me, but your routing is incorrect.
The fresh air hose goes to the passenger's side valve cover and the crankcase vapor go out from the valley cover into the intake manifold after the throttle blade. The Oil Catch can is put between the valve cover and the intake manifold after the throttle blade. This is so dirty air never touches the throttle blade.
There are a number of routing diagrams posted on the forum.
Old May 19, 2011 | 10:01 PM
  #33
B-Vette's Avatar
B-Vette
Originally Posted by FrankTank
It's always interesting to me the amount of people on this forum who don't care about oil in the intake, and won't buy a catch-can. Their reasoning is that there are thousands of daily driver corvettes that don't have catch cans and they run fine, and there is no documented proof of engine failure due to oil in the intake manifold.
While that may be true , oil in the intake is not supposed to be there regardless, a catch-can IMO is a cheap simple way to keept things clean. I would think if a lot of oil is in the intake the engine is not operating the best it can, and detonation is possible.
Oh well, I guess you can lead a horse to water, but you can't make it drink it
I had an Elite Engineering catch can put on my 2000 LS1 and it worked great. I'm planning on putting one on my 2007 LS2.
Old May 19, 2011 | 10:53 PM
  #34
iamkandana's Avatar
iamkandana
5th Gear
Old May 20, 2011 | 07:01 AM
  #35
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
You are quite right. My routing got twisted in my mind while I was writing.
Old May 23, 2011 | 04:14 AM
  #36
MisterMidlifeCrisis
I redid the mounting for my catch can. It was a bit wobbly being mounted to the battery hold down bolt so I fabricated a new mount that uses the rear bolt for the hood latch.
This shortens the mount significantly and makes it much more stable. It does get slightly in the way of the fuse block cover but all of the fuses are still fully accessible. Also, to get to the set screw to release the catch can, it's necessary to just twist the catch a bit so the allen wrench can access the screw.
The bolt holding the plate steel strip to the mount looks pretty ugly, but it has a split lock nut on either side and it was all I had at the moment. I still need to trim the plate strip a little bit as it's too long, and probably will also finish it up by painting it black at some point.
It clears the hood by a significant margin. I put three layers of bubble wrap on top of the catch can and closed the hood and it didn't pop the wrap so there's probably a good inch or more of clearance, and it only sits less than half an inch above the battery and fuse block.
Old May 23, 2011 | 06:52 AM
  #37
VET4LES's Avatar
VET4LES
Looks good.
