PCM Replacement
Old May 17, 2011 | 06:07 PM
tudac3-5-6's Avatar
tudac3-5-6
Default PCM Replacement
Has anyone replaced the PCM? If so, how was it done? Computer required?
Thanks!
Old May 17, 2011 | 07:54 PM
RicK T's Avatar
RicK T
Just to be clear, C6's don't have a PCM (this was the Powertrain Control Module in the C5). The C6 has separate ECM and TCM (Engine and Transmission Control Modules).
Not sure what you're asking.......assuming you're interested in the ECM are you asking how to physically change an ECM or asking if there is programming involved when a new one is installed?
Old May 17, 2011 | 08:35 PM
tudac3-5-6's Avatar
tudac3-5-6
I thought ECM was correct also! One parts man told me PCM!
I am going to put a new one in and have it tuned! I will keep the original...in case!
Thanks!
Old May 17, 2011 | 08:36 PM
RicK T's Avatar
RicK T
Ah, okay.....then this thread I saved may tell you what you need:
http://forums.corvetteforum.com/c6-c...stock-pcm.html
Old May 17, 2011 | 09:42 PM
MADinAK's Avatar
MADinAK
St. Jude Donor '06-'07-'08-'09-'10,'14
Thanks!
In case of what?
Old May 17, 2011 | 10:31 PM
MARSC6's Avatar
MARSC6
The new ECM will need programmed for your car.
Old May 18, 2011 | 06:05 PM
tudac3-5-6's Avatar
tudac3-5-6
Thanks MARSC6! That's what I thought...just wanted to back myself up!
To PCM Replacement
