Rebuild Torque Tube???
A while back I put an aggressive "puck" style clutch in my car (long boring story.) The clutch chattered like a magpie. I tried to put up with it because the vendor said it would smooth out as it broke in. Several thousand miles later I changed out for a less aggressive full disk kevlar clutch...but.....
I now hear lots of rattle and knocking in the drive line (sounds like a rock tumbler) AND I still have a fair amount of chatter in what is supposed to be a chatter-proof clutch. I suspect my torque tube couplers may have been torn up a bit by the abuse the first clutch put on them (when it would chatter the whole car would quake violently)...but i don't know how to tell if the torque tube is healthy.
So here are my questions and thoughts..
1. Can sloppy couplers in the torque tube cause symptoms that feel like clutch chatter? I'm wondering if maybe the clutch is fine and the couplers are the problem?
2. Could engine or tranny mounts get sloppy without tearing and allow excessive drive train movement? The shifter wiggles like crazy when the clutch chatters.
3. Are there any good threads (I have not found any) on torque tube rebuild? I have no idea of what tools and parts may be needed.
4. If I go forward and come to a stop, put it in reverse, then as I let out the clutch there is a pretty easy to hear metallic "clack" that sounds like slop being taken up in the drive train. Is this normal? I don't remember the car having this before, but its been a while since I changed the clutch.
Thanks for your responses.
-Dale
Just some discussions that may help:
http://forums.corvetteforum.com/c6-c...-question.html
http://forums.corvetteforum.com/c6-t...ube-noise.html
A post excerpted from a great trans rebuild thread in C5 that I saved:
http://forums.corvetteforum.com/1567912008-post43.html
I've watched the clutch get changed out on my car twice, so I think I could do it myself. Its a lot of work, but not rocket science by any stretch. The main thing that might force me to get it done instead of doing it myself is I don't have access to a lift and I am having big doubts about trying to do it on the floor of my garage with tall jack stands. Its just hard to pay over 1K in labor for a 1 to 2 day job.
Sounds like I should just go ahead and rebuild the TT while its torn apart. Thanks for the insight into what it will take to do this part of the job.
-Dale
PS I also think I will probably replace the engine and tranny mounts while its all apart, but man the bill just keeps getting bigger. A few 100 here and there and eventually we're talking big real money.
http://forums.corvetteforum.com/c6-t...ion-4-0-a.html
Sean
TT Rebuild Kit from ECC - Bushings and Bearings
While im in there.....
Updated 09 and up shifter assy
Slave with remote bleeder
Pilot Bearing
ARP F/W and Pressure Plate bolts.
Im still thinking which clutch and flywheel im going to go with. Maybe an LS7 maybe aftermarket.
Ive done a bit of research on here and printed out a few posts documenting the process. Heres some tools you may need for the job.
Pilot Bearing Puller/Remover
Metric Wobbles
13/16ths deep
24MM Socket
Snap Ring Pliers
9’’ Ring Pliers
I saw a thread a while back, maybe it was my thread, I dunno. Anyways someone posted this link. Very helpful.
http://www.gmhightechperformance.com...kit/index.html
Im going to tackle this in about a month on my vacation. I just need to pick a clutch dammit!
Pilot Bearing
Metric Wobbles
13/16ths deep
24MM Socket
Snap Ring Pliers
9’’ Ring Pliers
Also when I drop the torque tube, I separate the cradle from the differential. Then I drop the transaxle, and tube as a complete assembly. I have a rack and a great transmission jack with the GM adapter on it so it makes my job a lot easier. Trying to wrestle the complete transaxle and tube out without the GM adapter or something like it would be scary as the transmission isn't what one would call flat on the bottom where it would rest securely on a jack plate, and you need to lift it at the transmission because that is the balance point.
Here is what it looks like on my transmission jack:
Depending on your mods, a stock car can just use the factory replacement LS2/7 clutch. Its a decent clutch for the money. And works fine even with some drag strip use. A excellent clutch is the ZR1 clutch being offered by Katech and LPE. That unit will handle just about anything you can throw at it and feel like a stock clutch.
If you do choose this route, it only takes about 17-20 bolts (excluding the center console/shifter) ot get the assembly out plus applicable electrical connectors. If I had to do it over again, I could have the clutch out in about 4 hrs once the car is on stands
Thanks everyone for the advice. I've seen the procedure done twice, so sometimes I think.."not that bad...I can do it." Then other times I think.."man it would be nice if someone else would that for me.
-D
Pilot Bearing
Metric Wobbles
13/16ths deep
24MM Socket
Snap Ring Pliers
9’’ Ring Pliers
I wasnt comfortable taking it out as one. I dont have a good tranny jack either. Plus im on 4 jack stands.
The cradle part was easy. My diff mounts look good. I did find one broke lowering bolt though.
Im going to pull the diff and the tranny piece by piece. Since this is my first time I feel more comfortable that way because I can see how everything goes together. Its a few extra steps but I have to break the tranny off of the TT anyways for the rebuild.
