Oil
Old May 23, 2011 | 12:26 PM
Happihank's Avatar
Happihank
Default Oil
Ive got 50,000 miles on my C6 Z51 Manual. Ive always used the recommend oil - any thoughts about using something heavier? Its my DD and I usually put in a 1/4 pint every other month. Doesn't leak - just the shifting and stop and go fwy out here in LA.
Old May 23, 2011 | 02:59 PM
VET4LES's Avatar
VET4LES
I would stay with Mobil 1 5w-30. 1/4 pint is next to nothing. I see no reason to change.
Old May 23, 2011 | 06:18 PM
RicK T's Avatar
RicK T
Originally Posted by VET4LES
I would stay with Mobil 1..... 1/4 pint is next to nothing. I see no reason to change.
At 50,000 miles it's just really getting broken in......stick with what has worked and no doubt will continue to work.
Old May 23, 2011 | 06:22 PM
1 C6 2NV's Avatar
1 C6 2NV
Myth Buster
5w-20????
Old May 23, 2011 | 06:26 PM
RicK T's Avatar
RicK T
Originally Posted by 1 C6 2NV
5w-20????
Typo.
Old May 23, 2011 | 06:41 PM
KB9GKC's Avatar
KB9GKC
I would stay with Mobil 1 5w-20. 1/4 pint is next to nothing. I see no reason to change.
Old May 23, 2011 | 07:59 PM
VET4LES's Avatar
VET4LES
5w-20????
Originally Posted by RicK T
Typo.
You got me. 5w-30.
Old May 23, 2011 | 10:57 PM
1 C6 2NV's Avatar
1 C6 2NV
Myth Buster
Well you never know? Strange things happen I run 10w30 mobil 1 and 6 qts here in South Texas. I prefer a little heavier summmer weight for the heat
Old May 25, 2011 | 02:41 PM
el es tu's Avatar
el es tu
I would recommend:
Mobil 1 5w30
Mobil 1 0w30
Mobil 1 Racing 0w30
the regular M1 0w30 and 5w30 are GM approved
the racing one isnt GM approved because it isnt good for cats, but it has the strength of a thicker oil and a better additive package... Price is also double of what regular costs.
Old May 25, 2011 | 02:59 PM
Bill Suttie's Avatar
Bill Suttie
If you are back gearing in traffic ie using the engine to slow the car to save you brakes, you will burn some oil. A quarter pint in a month (milage?) is cheaper and easier to replace that brake pads. Keep using the recommended oil and don't worry.
Old May 25, 2011 | 04:54 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Stick with the factory Mobil 1. I LOVE the oil threads that get started around here... unless you track the car all the time, there has never been any solid proof that the factory recommended oil is not sufficient.
Old May 25, 2011 | 07:52 PM
timd38's Avatar
timd38
I use Mobil 1 oil in the crankcase and RedLine in everything else.
Old May 25, 2011 | 07:59 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Originally Posted by el es tu
I would recommend:
Mobil 1 5w30
Mobil 1 0w30
Mobil 1 Racing 0w30
Unless you're in a very cold climate, there is no need for a 0w30. Also, racing oils are not always good for use on street engines. True, they do have more zddp, but they typically lack additives and detergents that non-race engines need to fight against fuel dilution and moisture. Just because it says "racing" on it does not mean its better for your daily driven car as well.
Old May 25, 2011 | 09:44 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
Excellent point
Old May 26, 2011 | 07:34 AM
el es tu's Avatar
el es tu
M1 Racing for motorcycles is known for that. It doesnt have the additives that the non motorcycle oils have because of the clutch slip problems that would ensue.
Doing a some searching a while back lead me to the fact that M1 racing (the non motorcycle spec) is not recommended for street use because 1: it is bad for the cats 2: The US has a stricter standard on the amount of additives that go into oil than you see in other vehicles such as those in europe.
If they had an m1 racing 5w30 I would recommend that (it only comes in 0W30 and 0W50), but just because it is a 0W oil doesnt mean it is an oil tailored mainly for the cold. The oil has the strength of thicker stuff. The charts are right there on the mobil 1 website.
http://www.mobil.com/USA-English/Lub...cing_Oils.aspx
http://www.mobil.com/usa-english/mot...duct_guide.pdf
Lastly, I wouldnt recommend this oil for a DD because you would be spending 100 dollars per oil change, however I do recommend it for street cars that see hard use such as weekend fun cars.
Old May 26, 2011 | 12:08 PM
Happihank's Avatar
Happihank
Default thanks to OIL
Thank you all for the input and advice. Ever since I got my car, this forum has been a reliable source for discussion and information. Have a great Holiday weekend!
Old May 26, 2011 | 02:49 PM
RDKING's Avatar
RDKING
I use 10W/30W in Fl.
To Oil
Old May 26, 2011 | 06:17 PM
dbaker's Avatar
dbaker
I recommend this......
\db2
carolina
Old May 27, 2011 | 02:49 PM
ScaryFast's Avatar
ScaryFast
75W-90.
Smells better.
Old May 27, 2011 | 04:00 PM
66biskwik's Avatar
66biskwik
Lingenfelter recommends 15W50 summer and 10W/30 in winter with their packages.
