Best Tires
Old May 25, 2011 | 10:48 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
Originally Posted by StKnoWhere
Which Hankook are they or you refering to? I'm looking for the RE-11 now also.
Old May 26, 2011 | 10:36 PM
StKnoWhere's Avatar
StKnoWhere
Hankook Ventus R-S3
Sorry, here's the entire thread
Generally, the RE-11 seems to be a top choice for a all around performance street tire (wet and Dry) and the Hankooks for maximum dry grip.
Checkout these threads.
http://forums.corvetteforum.com/whee...-tirerack.html
http://forums.corvetteforum.com/c6-t...292-tires.html
http://www.tirerack.com/tires/survey...ay.jsp?type=EP
http://www.tirerack.com/tires/tests/...y.jsp?ttid=118
Old Jul 11, 2011 | 11:59 AM
motorbreath19842004's Avatar
motorbreath19842004
Originally Posted by Cbjorgol
I didn't even know 295's would fit on my stock rims. Will Amy tire place be able to put them on?
I just went from 285/35's to 305/30's (Pirelli P-zero rosso), on stock 19x10 wheels...... no spacer needed..... tires are still inside the quarter panel...... No traction control issues yet..... Difference in traction is huge!!! I have a 2005 A4 trans. Before, 1 & 2nd gear would spin very violently with the pedal to the floor, but now I can hold the brake, press the gas to the floor (engine stalls @ 1600) then just dump the brake..... very short tire chirps in 1st AND 2nd!!!! Without spinning, It feels like I just added 100 hp!!! 305/30 will still be a little shorter than the 285/35, but it will be closer to the same height than the 295/30 will be.
Old Jul 11, 2011 | 08:51 PM
glennhl's Avatar
glennhl
Best dry traction in stock sizes: Kumho XS
