Best Tires
Old May 23, 2011 | 12:40 PM
ImpatientlyWaiting's Avatar
ImpatientlyWaiting
Default Best Tires
I know very little about tires and I want to know which ones would be the best to look at. I do NOT drive my car in the rain and I really just want maximum traction. I looked at thetireson a GTR and they were borderline racing slicks and all I could think was that those must GRIP!! I want to remain street legal and keep my factory rims. I have a 2007 z51 if that matters.
Old May 23, 2011 | 03:36 PM
Vito.A's Avatar
Vito.A
The best grip tire I have tried is the Michelin Pilot Sport Cup. The Michelin Pilot Sport Cup is a new 2012 option for the ZR1. They are soft and will only last about 10K miles.
If you are looking for the best straight line traction, then Mickey Thompson or Hoosier 275/40-17 drag radials are the best.
Old May 23, 2011 | 03:46 PM
ImpatientlyWaiting
What would be a reason not to get the drag radials? Why are they so much cheaper? And will they fit on my car with my current rims?
Old May 23, 2011 | 03:56 PM
Ragtop 99's Avatar
Ragtop 99
Handling around curves will probably be compromised.
drag radials currently available do not fit on the stock rims. Some are on the way, but it seems they have been promised for months.
Toyo R888s are an r-compound tire and fit on stock rims.
Old May 23, 2011 | 04:05 PM
ImpatientlyWaiting
Do you know where I can get those in 285/35-19 and 245/40-18?
Old May 23, 2011 | 04:26 PM
bdanyluk's Avatar
bdanyluk
Nitto Invos.
Old May 23, 2011 | 04:27 PM
Ragtop 99's Avatar
Ragtop 99
285s are not available. Most squeeze the 305 on to their stock rims. There is also a 295 size.
Google "Toyo R888" and several on-line vendors will pop up.
Old May 23, 2011 | 04:28 PM
Gering's Avatar
Gering
Tolero Apto Victum
I may have to try these out. I love corners!!!
Old May 23, 2011 | 04:30 PM
breecher_7's Avatar
breecher_7
Originally Posted by bdanyluk
Nitto Invos.
Definitly a good tire, but not anywhere near the best.....
Another vote for Toyo R888
Old May 23, 2011 | 04:33 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Nitto Invos.
It's a good commuter tire, but not good for anything performance related.
In stock sizes I'd look at Khumo XS or Potenza RE-11s
For something a little more affordable and still quite decent the Hankook Ventus V12 is awesome. I have them on my C6 right now (Putting a full set on my XLR-V) but will be swapping the rears to the RE-11s once I wear them out now that the car's pushing more power.
Old May 23, 2011 | 05:15 PM
tomiboy's Avatar
tomiboy
Old May 23, 2011 | 06:38 PM
bdanyluk's Avatar
bdanyluk
Don't think he was looking for a track only tire.....whatever....as long as you don't buy runflats, it will be waaaayyyyyyy better than stock.
Old May 23, 2011 | 08:37 PM
ImpatientlyWaiting
I didn't even know 295's would fit on my stock rims. Will Amy tire place be able to put them on?
Old May 23, 2011 | 11:17 PM
doveboat's Avatar
doveboat
On stock C6 Split Spokes (08) I run the R888's & Michelin Pilot Super Sports:
255/35/18 Fronts
295/30/19 Rears
These sizes maintain the Front to rear diameter variance, so no electronic issues, also no rubbing.
Ed
Old May 23, 2011 | 11:30 PM
ImpatientlyWaiting
255/35/18 Fronts
295/30/19 Rears
Ed
That sounds like a good idea actually, radials for traction and the pilots for handling, both where they count. Thanks!!!
Old May 24, 2011 | 09:18 PM
StKnoWhere's Avatar
StKnoWhere
RE-11
Old May 24, 2011 | 09:37 PM
jdwk's Avatar
jdwk
I am a very happy owner of the RE-11's, but will most likely step up to a DOT legal R compound on my next set, probably R888 as the RE-11's are lasting much longer than expected and will most likely dry out before I can use all the tread. They are still very soft though after 15 months in the AZ desert.
To Best Tires
Old May 25, 2011 | 10:53 AM
APSGTO's Avatar
APSGTO
I believe those are both stiff sidewall tires, so they are both for handling.
Hoosier R6 > R888 > PS2 Cups > RE-11 > NT05 > all others.
Old May 25, 2011 | 11:52 AM
KneeDragr's Avatar
KneeDragr
Hoosiers! Deadly in the rain but they will stick like glue in the dry.
Old May 25, 2011 | 07:28 PM
StKnoWhere's Avatar
StKnoWhere
Hankook was the winner here:
http://forums.corvetteforum.com/1577709853-post5.html
