Early Model Z06 Differential Question...
Old May 23, 2011 | 08:47 PM
jpuli28's Avatar
jpuli28
Default Early Model Z06 Differential Question...
Hey guys, Im looking at a NIB Z06 Differential (never installed). Ad says it fits 06 or 07 model years. Was there a difference in the units back then? Any problems? I have an 07 A6 im gonna install it in fwiw.
Old May 23, 2011 | 09:04 PM
RicK T's Avatar
RicK T
I'm not aware of any differences but........?
Here's what thesubfloor says about swapping into an '07 A6:
Originally Posted by dboelens
My car is an A6 2007
Originally Posted by thesubfloor
Call Pfadt Racing, order their "offset differential mounts" and voila, it becomes a straight bolt-in without any needed changes to the transmission.
Since the Z06 comes with integrated cooler lines you'll have two choices regarding those - either leave most of them intact and install a loopback hose (on the little supplemental cooler on the left side of it) or you can plug the lines and install a replacement cover (from Zip Corvettes, I believe) to remove the cooler entirely.
Old May 24, 2011 | 02:56 PM
jpuli28's Avatar
jpuli28
Well I may have been talked out of it. Suggested was keep the 2.56 and go with a Yank 3200 only. Perfect set up for a DD with a future of being SC.
Also does anyone know of a spline difference 28 vs 30 between the A6 tranny and the Z06 diff?
Old May 24, 2011 | 03:35 PM
HoosierPE's Avatar
0HoosierPE
Former Vendor
They are both 30 spline.
Old May 27, 2011 | 08:23 PM
jpuli28's Avatar
jpuli28
Thanks. If I wanted to add a cooler to the diff is there an oem setup I could purchase? The only one I can find is from LG (I think) for $1k+
To Early Model Z06 Differential Question...
