2006 z51
Need some advise from all the experts on this forum.I recently noticed twice service fuel tank msg when the fuel tank got almost empty.When I fill the tank up the msg goes away.Any ideas why I am getting this error code.Is this something that needs to be looked into or just the code needs to be reset.
The car has 60k miles on it.
Thanks again for all your help.
#05-00-89-078B: GM Fuel System Treatment PLUS, Fuel Sending Unit Corrosion and Fuel System Deposits - (Feb 6, 2008)
Subject: GM Fuel System Treatment PLUS, Fuel Sending Unit Corrosion and Fuel System Deposits
Models: 2008 and Prior GM Passenger Cars and Trucks (including Saturn)
2008 and Prior HUMMER H2, H3
2005-2008 Saab 9-7X
This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 05-00-89-078A (Section 00 -- General Information).
Important : The GM Fuel System Treatment PLUS is not recommended for use with diesel fuel. The GM Fuel System Treatment PLUS is specially formulated for use in gasoline and/or E85 fuels.
GM Fuel System Treatment PLUS, P/N 88861011 (for U.S. ACDelco®, use 88861013) (in Canada, 88861012), is now available for use in gasoline engines.
Added Benefits and Uses
The PLUS portion of GM Fuel System Treatment PLUS is the addition of a filmer additive that, when used regularly, can protect fuel system sending units from the corrosive effects of certain sulfur contaminants found in some of today's gasoline.
Sulfur contamination can disrupt electrical continuity of certain fuel sending units and lead to erratic or false fuel gauge readings. With scheduled usage, GM Fuel System Treatment PLUS protects against the effects of harmful sulfurs in gasoline.
The Four Benefits
Just pour in one bottle of the GM Fuel System Treatment PLUS into the fuel tank when refueling around each oil change interval:
• Cleans -- Sulfur corrosion from fuel gauge sending units.
• Prevents -- Harmful sulfur components from attacking sensitive fuel system electronics.
• Protects -- By coating metallic surfaces of the fuel system.
• Removes -- Engine deposits left from use of poor quality fuels.
Parts Information
Part Number
Description
88861011 (for U.S. ACDelco, use 88861013)
