Z51 brakes
Old Jun 6, 2011 | 06:39 AM
glenn c6's Avatar
glenn c6
Default Z51 brakes
can you use stock c6 calipers with Z51 brackets and rotors or do you need Z51 calipers?
Old Jun 6, 2011 | 06:43 AM
breecher_7's Avatar
breecher_7
Stock calipers will work just fine, the only difference between the calipers is the rear z51 actually has a slightly smaller piston (few mm smaller). Brackets and rotors are all you need.
