Time retard switch
Old Jun 12, 2011 | 07:54 PM
Bill K C6's Avatar
Bill K C6
Default Time retard switch
Can anyone tell me what i can use to retard timing by switch for a nitrous set up?
Old Jun 12, 2011 | 08:16 PM
majorpayne317641's Avatar
majorpayne317641
You may have some MSD iginition controllers that would work for your set-up, I would advise the best way however is to hop on HP tuners and change the advance to work with your nitrous setup, you may notice a difference when not using it but you are definitely going to be safe when spraying. The best part about it is you can have two tunes, when you want to use your nitrous for whatever day, you would load that tune, and you would load your street tune when your not using it. Hope that helps.
Old Jun 12, 2011 | 08:36 PM
ls3gotcha's Avatar
ls3gotcha
msd timing twister. It only pulls timing while the kit is activated
Old Jun 12, 2011 | 09:08 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Spinmonster came up with a very clever way.
Check out his post in this thread.
http://forums.corvetteforum.com/c6-t...nd-advice.html
To Time retard switch
