Switch to high temp brake fluid
Old Jun 13, 2011 | 03:39 PM
Brinton-Z06's Avatar
Brinton-Z06
Default Switch to high temp brake fluid
When switching to a high temp brake fluid like Motul is it necessary to bleed the ABS. If you don't what affect will the mixing of brake fluids with different boiling points have on the resulting boiling point.
Old Jun 13, 2011 | 04:25 PM
BEZ06's Avatar
BEZ06
Well.....it's not necessary to bleed/flush the ABS circuits, but you'll have old DOT 3 in there that probably should be flushed out.
If you flush new Motul into your system, then go out and get into the ABS, the old fluid from the ABS circuits will mix with your Motul, and the result will be that it will degrade your Motul a slight bit.
However, that's exactly the procedure that some of us use when we don't have a Tech 2 to cycle the ABS valves when flushing - flush, go out and do several ABS stops, come back and flush again. Here's a quote from a StopTech document:
But What If I Don't Have The Dealer Service Tool?
If you really feel the need to cycle the valves, but do not have access to a service tool (or if the dealer is not willing to loan theirs) you COULD just replace Step #2 above with "go driving and slam on the brakes a few times to make the ABS work" to purge the used fluid from the unit. This is usually NOT the most efficient nor socially responsible solution, though it seems to work just fine. You still need to bleed the car a second time, but it saves you from procuring the service tool.
The entire document is here:
http://www.stoptech.com/tech_info/wp_bleeding_abs.shtml
Bob
Old Jun 13, 2011 | 04:49 PM
Brinton-Z06
Thanks for the info. Do you know who made the ABS is on the 09 Z06?
Old Jun 13, 2011 | 07:41 PM
BEZ06's Avatar
BEZ06
Bosch
Delphi made it for the 2005-2009, but they switched to Bosch in 2009.
Functionally they're not very different, but the parts aren't interchangeable.
Bob
To Switch to high temp brake fluid
