Which Supercharger and why?
Old Jun 29, 2011 | 05:16 PM
jthurik's Avatar
jthurik
Originally Posted by NYC6
Just curious, from what do you base your opinion on?
The numbers from all the cars that come out of Dallas Performance
John
Old Jun 29, 2011 | 05:37 PM
turbotuner20v's Avatar
turbotuner20v
You have a Z51 car, so there's an additional twist to your kit selection... You will need a new radiator with the A&A/ECS kit, where the procharger kit will work fine with your existing radiator and coolers.
I have a ProCharger kit on my car and love it. Definitely go for the D-1SC upgrade at the time you purchase the kit... the cost it minor and the room to grow is great.
Here is my dyno at 7psi (559whp) and 8.5psi (604whp) on a D-1SC on a stock '09 LS3 6MT Z51 on 91 octane.
Old Jun 29, 2011 | 05:51 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
On the 08+ Z51 manual cars, most of them do have the oil cooler that is in the same spot as our intercooler and you either have to relocate the cooler or add the radiator with the built in oil cooler. You do, however, get the benefit of a dual core radiator. You also get a intercooler that sits down in the front fascia, not in front of the A/C Condensor and the Radiator.
Old Jun 30, 2011 | 09:57 AM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
The ECS kits DO NOT require a new radiator - It was designed to work with the Z51 and Z06 Radiators. Also the ECS Kits are designed so that Z51 Cars retain the factory oil cooler. I don’t know where people get this information from. The A&A & ECS kits are substantially different in this respect. Additionally, our base kits come with upgraded steel idlers, a HD belt tensioner, A larger head unit, larger diameter and a great percentage of solid vs aluminum ducting, more belt wrap there are alot of little difference that add up when you lay the products out side by side.
Old Jun 30, 2011 | 10:58 AM
NYC6's Avatar
NYC6
Hes says hes a "turbo tuner" and not a "super charger tuner" maybe that explains his confusion.
Old Jun 30, 2011 | 11:25 AM
turbotuner20v
Sorry, I thought the ECS/A&A kit were very similar and figured they had the same radiator/oil cooler issue on Z51 cars. Thanks for clearing that up.
Old Jun 30, 2011 | 02:29 PM
boraxman's Avatar
boraxman
Are the ECS Paxton kits CARB certified at all?
Old Jun 30, 2011 | 03:08 PM
MARSC6's Avatar
MARSC6
ECS kit
Very easy to up the Hp. I just added alky and fuel to the base kit for 735hp on the stock never opened engine.
Old Jun 30, 2011 | 04:10 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In V Veteran
Nope. No CARB Certs Sorry. I believe the only existing Centri Corvette System that that is Certified is Procharger.
Old Jun 30, 2011 | 04:15 PM
LS7 ZO6's Avatar
LS7 ZO6
Originally Posted by Steve@AandACorvette
I would have to say A&A.
Why pay more
Old Jun 30, 2011 | 04:53 PM
gunterwalker's Avatar
gunterwalker
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
ECS or A&A. Only way I'd go. ECS has done work on my car and I can say they are the best.
Old Jul 1, 2011 | 07:09 PM
JustinStrife's Avatar
JustinStrife
I own a procharger D1sc and my suggestion is an A&A Trim or a Ysi. Great products and great service.
