broken timing chain on LS2
Old Jul 2, 2011 | 06:32 PM
truckplay's Avatar
truckplay
Default broken timing chain on LS2
I broke the timing chain on my 05 this morning under accellaration. I am looking for advice on Chain set, cam ... Is a gear to gear timing set available ( I love the sound ) I am running 1 7/8 headers, uncatted Z06 exhaust, ported fast & ported t-body, Varaam & 25% underdrive pulley (i believe this is the cause of the failure)
any suggestions or links would be appreciated.
Old Jul 2, 2011 | 06:53 PM
Gering's Avatar
Gering
Tolero Apto Victum
What brand of underdrive pulley? There have been a few timing chains that have broke while using a certain brand of UP's.
Old Jul 2, 2011 | 06:57 PM
truckplay's Avatar
truckplay
slp 25%. i was told when i bought it, beacuse my oe "wabbled" that it could happen on DOWNSHIFTS not up shifts
Old Jul 2, 2011 | 07:12 PM
timd38's Avatar
timd38
Katech C5R chain appears to be the best.
http://store.katechengines.com/c5-r-...chain-p30.aspx
Old Jul 2, 2011 | 07:50 PM
Gering's Avatar
Gering
Tolero Apto Victum
Sir,
Please see my 2nd post, there are 3 threads that may help you out.
http://forums.corvetteforum.com/c6-c...ey-issues.html
Old Jul 2, 2011 | 08:47 PM
truckplay's Avatar
truckplay
Default how about Katech
does anyone have any knowledge of the C5r timing chain & Trac camshaft?
Old Jul 2, 2011 | 09:51 PM
truckplay's Avatar
truckplay
thank you. looks like i'm leaning to the katech with their cam. dont know if i need a kit with lifters and pushrods though. also i am gonna want to pin the crank. i didn't do it when i changed the pulley and don't remember why. i am so mad, the car only has 25k & I never track the car, only high speed runs on lonely roads
Old Jul 2, 2011 | 10:16 PM
Gering's Avatar
Gering
Tolero Apto Victum
When you have all of your work done, take a look at installing an ATI underdrive pulley.
Old Jul 3, 2011 | 01:08 AM
DSOMC6's Avatar
DSOMC6
I just installed the C5R timing chain to avoid the problem you have encountered. If you are going with a cam that has a higher lift than the OEM cam I would replace the lifters, add hardened push rods and dual valve springs.
Old Jul 3, 2011 | 07:02 AM
truckplay's Avatar
truckplay
thanks i will. i emailed a corvette shop by my house and am waiting on a reply. hoping to get the car running this week.
Old Jul 3, 2011 | 07:10 AM
timd38's Avatar
timd38
I don't know exactly when it appended, but GM changed to a stronger chain when the went from LS1 to LS2. Since you have an 05, maybe it came with the lighter chain and new stock LS2/3 chain will be fine.
Just a guess.
Old Jul 3, 2011 | 07:14 AM
truckplay's Avatar
truckplay
thanks, i am thinking of doing the katech c5r, seems very popular and haven't heard about any fitment issues as in double rollers, with a new cam kit.
thanks
Old Jul 3, 2011 | 11:25 AM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
You are probably going to need valves too from the piston contact when the chain broke. Since you have to pull it apart anyway, here is the direction I went with my 06....wanst that expensive and the performance difference from the bolt on LS2 was nothing short of phenomenal:
http://forums.corvetteforum.com/c6-t...cam-specs.html
When I did it, these were the part numbers and cost...it actually cost me much less as I sold all takes offs and did my own labor, so in the end it cost me about $700.00 total.
2 - L92 Heads Part # 012582714 $379.90
8 - Offset Rocker Arms for L92 Part # 012569167 - $94.72
8 - Manley 2.165" L92 Intake Valves # MAN11620 - $111.92
8 - Manley 1.590" L92 exhaust valves# MAN11621 - $111.92
2 - Rocker Pedestals for L92 Part # 012600936 - $31.04
1 - ARP Bolt Set Part # ARP1343610 - $98.95
1 - L76 Bare Manifold # 012590124 - $224.75
1 - Patriot Extreme Gold Spring Set - $279.50
1 - GM Crank Seal # 012585673 - $18.36
1 - IWin Heavy Duty Rollermaster Chain #SD3SR602 $42.35
From ByunSpeed
1 - Powerbond Underdrive Pulley, Belt, Bolt Kit - $200
From CompCams
1- Comp Cam 228/232 114+2 LSA - $404.00
Total of $1997.41
Old Jul 3, 2011 | 11:27 AM
truckplay's Avatar
truckplay
i didn't think it was an interference engine.
Old Jul 3, 2011 | 12:25 PM
Craigster05
Here's two 05s that I know of, and Ive never seen anyone break a chain that didnt destroy valves as well:
http://forums.corvetteforum.com/c6-c...-purchase.html
http://forums.corvetteforum.com/c6-t...now-c-o-w.html
After a chain failure, you'd have to pull everything apart just to be safe and sure. Either way, whether you got lucky or not, if it were me, I would take the opportunity to turn a negative experience into a positive one and rebuild with better parts to make her faster as well...but that's just me and I'll never claim to be the brightest bulb in the lamp
No matter what, best of luck, we'll hope for the best and hopefully you'll be back on the road soon.
Old Jul 3, 2011 | 01:55 PM
CMY SIX's Avatar
CMY SIX
it don't matter what brand pulley, these engine's don't like them!
Old Jul 3, 2011 | 02:08 PM
DSOMC6's Avatar
DSOMC6
The small gain in power isn't worth the risk IMHO.
To broken timing chain on LS2
Old Jul 3, 2011 | 02:22 PM
LS1LT1's Avatar
LS1LT1
Old Jul 3, 2011 | 02:53 PM
TNTC4VETTE's Avatar
TNTC4VETTE
Will work for HPDE time.
Interesting. I've had several lsx motors with under drive pullies and never any problems...but that's just me.
Old Jul 3, 2011 | 10:35 PM
truckplay's Avatar
truckplay
did you replace the heads ? that seems like a good deal if you did. i was thinking about having mine ported. thanks for your help.
tom
