Where can i find this wire after it leaves the fuse block under the hood? Can someone tell me which loom it's in when it leaves the block? And what color is the wire? I've done a search and all I've found is that it goes to #55 in the fuse block, but it's hard to tell which loom it leaves the block in.
The wire is grey and it exits the fuse box in one of the bundles underneath. Best thing to do is get a schematic of fuse box and lift the top of the box off to find the port with the grey relay wire. Then trace the bundle that it exits the box from. I used a schematic I found by doing a search on either installing a BAP or alky pump...forgot now. May still have it on my PC somewhere.
I don't remember which number it is, but it is larger and the only grey wire in the loom. It goes to the block behind your battery.
Mine had a bad connection there and killed a pump and several relays! I will check tonight when I get home from work if you don't get your answer by then.
Well thank u very much, that would help tremendously
No I'm sorry, my softball game ran a bit late and it was far too dark and rainy when I got home. Tonight's game is probably going to be a rainout and if so I will give you an update.
Sorry.
No problem man, ur helping me, no need to be sorry. Just let me know if u get a chance tonight. Thanks again
