ls3 intake maf on ls2
Old Jul 7, 2011 | 02:40 PM
veech's Avatar
veech
Default ls3 intake maf on ls2
I would like to use an ls3 maf/intake on my ls2... the plug is different though. anyone done this before? is there a link to it somewhere?
Old Jul 7, 2011 | 08:20 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
It's a little more involved. The pig tail you can get from Zip Products a forum vender <----------
Then copy the Air Temp table from an LS3 and copy it into your tune and then adjust the MAF tables and WOT.... that's all. Oh yea, if you are going to do this yourself get HPTuners and send them an email and get the beta2 version so you have access to the air temp table.
Or have a tuner do it.
Old Jul 8, 2011 | 08:37 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
http://www.halltechsystems.com/Hallt.../kbls2conv.htm
"AWESOME GAINS!!!! March 18, 2011
Reviewer: Nezzy from Omaha, NE United States
I installed the Killer Bee II set-up on my 07 stock C6 and it turned my car into a monster! Worth every penny, especially the tune! Jim helped with any questions we had and updated my tune when I installed headers!!!!"
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
Old Jul 8, 2011 | 08:38 AM
RoadRebel's Avatar
RoadRebel
All you need is the connector, avail from your favorite supplier and move the wire/pins over. And then rescale the temp etc with your favorite tuner
Phil
Old Jul 8, 2011 | 09:20 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Phil
MAF transfer code, not temp.
The code is completely different between the Delphi 85 MAF and the probe MAF sensor.
You forgot the MAF meter as well.
Our package includes everything including the MAF tables.
Old Jul 8, 2011 | 01:14 PM
veech's Avatar
veech
Phil
sweet!
Old Jul 8, 2011 | 01:17 PM
veech's Avatar
veech
I have the ls3/7 intake housing and maf already... just need the harness to make it "work"
also, I dont HPTuners or any way to tune it myself...
Old Jul 8, 2011 | 08:27 PM
RoadRebel's Avatar
RoadRebel
Pretty much what I said, The IAT (temp) as well as the MAF transfer functions need to be changed. Most dont even know they are different and some tuning packages done even have the ability to edit the temp transfer. He has a complete LS3 asm and only needs a bare connector to swap it over then his favorite tuner (ME) can edit the tune.
Old Jul 27, 2011 | 08:14 PM
bwfredette's Avatar
bwfredette
Default another question
I hope I am not highjacking this thread but I have more questions than I can find answers for.
Is there a problem with the IAT. I read somewhere that the ls3 MAF does not have the air temp sensor built in, is this true?
Also are the LS3 and LS7 P/N the same does anyone happen to have the part number?
What benefit does this ultimately provide? I know the lager tube allows more air at any given MAF reading (Hz) but does the LS3 MAF also have a higher frequency range or does it just allow for the larger tube & more air at a given frequency?
Lastly have does the MAF frequency patch play in to all of this? I understood the patch to extend the frequency range of the tables... so does the LS3 style MAF frequency range line up with the MAF Frequency patch?
If any one can answer these questions I think we would have a good start at putting all the MAF upgrade data in one place. I have not seen any soup to nuts on this subject yet.
Old Jul 28, 2011 | 10:24 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
The LS3 sensor has the IAT built in and is very responsive. I have installed and tune a bunch of these are they are a lot better than the 85mm MAF. The MAF Sensor will read 4096 g/sec, as long as the ECM supports it. The upgrade is very simple and not much to it. Just need a adapter harness, sensor and a place to mount it. The 102 mm MAF Housings are a great option. I have tuned S/C Vettes with this installed and makes 850 rwhp. So, it is a great option.
Old Jul 28, 2011 | 12:38 PM
ITS STOCK's Avatar
ITS STOCK
Does anyone know what way the wires are swapped when using just the connector and not a harness adaptor?
Old Jan 22, 2013 | 01:57 PM
CSexy06VY's Avatar
CSexy06VY
I know this is an old thread, but I just installed my ls3 intake, maf sensor and adapter harness on my 06, I need a tune with the ls3 maf tables, can anyone help me out? Thanks
Old Jan 22, 2013 | 02:04 PM
bwfredette's Avatar
bwfredette
download an ls3 stock tune from the tuners web site. If you can't get one email me
Old Jan 22, 2013 | 02:12 PM
CSexy06VY's Avatar
CSexy06VY
From HPtuners? I don't have that software, I have a t100 diablo tuner, will the stock ls3 tune work on a ls2?
Old Jan 22, 2013 | 04:46 PM
SpinMonster's Avatar
SpinMonster
http://forums.corvetteforum.com/c6-t...lications.html
I ran a Z06/LS3 maf on my car.
You get the connector and double the MAF tables as a starting point for the tune.
Any Colorado locals who want this done, I tune it for free.
SpinMonster
No, it needs a real tune.
Old Jan 22, 2013 | 04:48 PM
SpinMonster
All pinouts are in my thread above.
To ls3 intake maf on ls2
Old Jan 22, 2013 | 06:06 PM
bwfredette's Avatar
bwfredette
Default answer
no you can't use the tune, only the MAF table as a starting point.
The ls3 table would be a good start only if you have the same diameter tube as the ls3, but if you just pluged the sensor in to another pipe then it has no corelation. BTW I thought the LS2 swap out was the LS7 sensor (my memory is foggy here).
Also why did you switch out the sensor? are you runniing an SC. If so then the MAP needs to be swapped too. If you've just put a CAI on then this mod is a waste of time and money.
This tip might help too... I had alot of trouble getting the car to run well after I put my SC on. It kept going in to reduced power mode untill I set the max flow settings in the diagnostic tables.
Here are the LS3 Stock flow nummbers but like I said they are only good to a certain point. Spin's method of doubling the flow and tuning is a good tip to use:
2008 LS3 Stock MAF, 0-1500:
0.38977 0.38977 0.38977 0.38977 0.38977 0.38977 1.02596 1.70049 3.49489 3.89087 4.43822 5.13694 5.98703 6.98850 8.14133 9.44553 10.92045 12.57946 14.41494 16.46984 18.74852 21.24557 23.97036 26.91764 30.08747 33.48220 37.10053 40.95876 45.12003 49.54977 54.24800 59.21470 64.64062 70.44896 76.61176 83.14305 90.05578 97.33838 104.98443 112.99212 121.39701 130.43002 139.98325 150.05666 160.64574 171.66438 183.16678 195.15291 207.59006 220.46841 233.80396 247.78262 262.51855 277.90030 293.84482 310.37195 327.38702 344.73828 362.59918 381.68140 401.48569 422.26196 445.86618 467.67087 490.19186 513.44104 537.43036 562.17163 587.67682 613.95776 641.02643 668.89459 697.57428 727.07727 757.41559 788.60101 820.64545 853.56085 887.35907 922.05200 957.65161 994.16968 1031.61816 1070.00891 1109.35388 1149.66504 1190.95410 1233.23303 1276.51367 1320.80811 1366.12793 1412.48535 1459.89209 1508.36011 1557.90112 1608.52734 1660.25037 1713.08228 1767.03491 1822.12012 1878.34973
Old Jan 22, 2013 | 06:31 PM
CSexy06VY's Avatar
CSexy06VY
I switched to a stock ls3 air box/ air bridge, what ever its called, I do not have a supercharger yet, I got these parts for less than $100, I heard the ls3 airbox an maf sensor were more efficient/better than the ls2 setup, eventually I may swap motor over to a ls3,
I'm not good with this ecu tuning/adjustments how can I put that maf table into my tune without hp tuners?
Old Jan 22, 2013 | 06:40 PM
timd38's Avatar
timd38
After reading this, I now know why I wrote a check and had some tune it.....
