I should probably post a link for the Vacula I mentioned in my previous post. They are not cheap like the Motive and I was lucky and got mine as a gift from a friend. One of the things I use it for is draining the master cylinder reservoir before I start bleeding the brakes with the Motive. Just stick the hose in, squeeze the trigger and the reservoir is empty in a blink. Of course it can be used to bleed the brakes but you do have to be careful with how fast it pulls the fluid. If you open the bleeder screw too much it will pull a lot quickly.
If somebody wanted to use it to suck fluid out of their clutch master cylinder reservoir it would work great doing that as well. One squeeze and its empty.
Bill
