Engine Quits - No Codes
Old Jul 13, 2011 | 01:20 PM
GentleBen's Avatar
GentleBen
Cruise-In 7-8-9-10-11-12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Default Engine Quits - No Codes
I've had three instances over the past two weeks where, after sitting a red light for a long period, when I start moving (yes, with a green light) the engine quits for no discernible reason. No codes are sent to the DIC nor does my OBDII scanner report any set or pending codes.
It will immediately restart and either immediately quits requiring a second (or third) restart or continues to run with no further problem. It does not set any code that I can find and the most that shows is a few misfires (5 on plug 8, 1 each on plugs 7,6, and 5, with 0 misfires on all remaining plugs).
This has happened when (1 instance) the gas was a little below 1/4 filled and the last two times where the gas level was between 7/8ths and full tank. The air filter (K&N) was cleaned over two months ago and seems to be okay. Battery is a yellow top Optima and holds a consistent charge between 13.8 and 14.2 volts.
Anyone have an idea of what could be causing this?
Old Jul 13, 2011 | 01:25 PM
C7&7's Avatar
C7&7
do you have an aftermarket cam?
Does it stumble first or just flat out die when you go into the gas?
6 spd car?
Old Jul 13, 2011 | 01:42 PM
GentleBen's Avatar
GentleBen
Yeah, it's got an aftermarket cam (hey, its a complete Lingenfelter 403 engine) but that engine has been in the car since early 2005 and this is the first time that I have had this problem.
The car is a 6-speed manual and it doesn't stumble - just quits. It hasn't occurred while driving (i.e., under either hard or normal acceleration and shifting between 1st - 2nd or 2nd - 3rd gears) nor does it occur every time I drive the car.
Since it is an intermittent problem it is hard to troubleshoot, especially when it does not set a code.
Old Jul 13, 2011 | 01:46 PM
C7&7's Avatar
C7&7
I had a similar issue like this after I installed my FAST 102, but it was just an idle stumble / die and it only happened when it got warm.
I had to add 5% to the air flow table in neutral.
Mine threw 0 codes also.
Old Jul 13, 2011 | 02:26 PM
GentleBen's Avatar
GentleBen
Tim, thanks for the idea but since the engine (and associated FAST 92mm intake) have been in the car for the past five years I don't see this as the root problem but will check it. I will admit that at all times it has been with high outside heat.
Old Jul 13, 2011 | 03:22 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
doubt if it's fuel related. electrical like IAT?
Old Jul 13, 2011 | 03:25 PM
Harbinz51's Avatar
Harbinz51
Clean the MAF meter if you just oiled your K&N not to long ago
Old Jul 13, 2011 | 03:45 PM
GentleBen's Avatar
GentleBen
Okay, I'll check/clean the MAF. Thanks!
Old Jul 14, 2011 | 12:10 PM
Shrike6's Avatar
Shrike6
Somba master
Cruise-In 7, 9 & 12 Veteran
St. Jude Donor '07-'08-'09-'10-'11
Bad gas?
No, not the Tex-Mex kind.
It's sure a strange problem.
Old Jul 14, 2011 | 12:18 PM
el es tu's Avatar
el es tu
had a similar problem with a firebird. dealership tried throttle body cleaning, resetting the ecu etc. turned out to be the ecu being messed up requiring replacement of the unit.
Old Jul 15, 2011 | 08:02 PM
GentleBen's Avatar
GentleBen
Default Problem Continues
I've cleaned the MAF Sensor and took the car out for a quick spin. Seemed to have cleared until the 15-minute mark when I was idling at a red light. Unlike earlier incidents, it did not stop while at the light but immediately after I started to move. It was not a stutter or stumble it just stopped - bang! It immediately restarted and I did not have another problem but this is becoming a real pain under the pistol belt.
To reiterate, the car is a 2005 Z51 with 6-speed manual, a Lingenfelter 403 engine, K&N air cleaner (cleaned/re-oiled in mid-May), yellow top Optima which holds 13.8 to 14.2volts, and it shows no codes (posted or pending) on my scan tool.
I'm at a loss and hope someone can provide some more ideas on what to check next.
Old Jul 15, 2011 | 08:28 PM
Curvhog's Avatar
Curvhog
1st Gear
Had a similar problem where my '07 would suddenly stop running or fail to start. What eventually was found by the techs at the dealer was a loose ground wire on what I would assume would be the main fuel pump since the C6 has 2 pumps, one of which is to transfer fuel between the tanks.
The abruptness of the engine stopping had me convinced it was a fuel problem but the fault never seemed to set a permanent code and it was only because I let the dealer drive it with data collectors attached that they found and fixed the problem after it failed to start on them. I had even had it towed to the dealer one time and tried to start it for the service guy and failed but amusingly while we were in his office one of the dealer's men got in started it no problem and drove away.
Old Jul 15, 2011 | 09:17 PM
Streetk14's Avatar
Streetk14
Well, you could hook up a mechanical fuel pressure gauge under the hood and tape it to the windshield for testing. This would tell you if it's a fuel system issue when it dies. Could be a poor connection somewhere or a sensor going bad.
You might want to have someone with a Tech2 look at the codes. I know my cheapy Matco scan tool will not show codes that are not currently present (ie. check engine light on). There could also be one stored in the body module that could help identify the problem.
My first thought was air mass meter as well, since you just oiled the filter. It will cause a check engine light, but the engine should run okay if you unplug the MAF. Might want to try that to see if it eliminates the problem.
Hope this helps....
Old Jul 17, 2011 | 11:11 AM
z51vett's Avatar
z51vett
Check plug wires to see if they are shorting out. Had #8 fall off plug after just a gentle pull, my trouble was an erratic miss fire tech could not find the problem. Ground wires or fuel pump need to get gauge and hook it up.
z51vett
Old Jul 18, 2011 | 12:12 AM
HANNY's Avatar
HANNY
air flow sensor issue
throttle position sensor issue
fly by wire throttle sensor issue v(at your foot)
Old Jul 19, 2011 | 01:57 PM
Harbinz51's Avatar
Harbinz51
I believe this could also be a loose ground on the Engine. Check all grounds
Old Jul 22, 2011 | 10:42 AM
GentleBen's Avatar
GentleBen
Default New Symptom
Now it is beginning to cut out while driving. I had gone approximately .5 miles past the stop light and, while driving in a straight line at about 2,000 rpm, the engine quit. It immediately restarted and I completed the drive to the office when another symptom began. When I pulled into the garage to park the car the engine began to oscillate between 1,000 and 500 rpm and run very rough until it just stopped. Again, no codes are showing on the DIC or on my OBDII scanner.
I will be "head down" in the engine bay this afternoon trying to see if I have a loose ground or if a spark plug boot is not firmly seated.
Anyone have any ideas of what could be causing this? I'm at my (half)wits end.
To Engine Quits - No Codes
Old Jul 22, 2011 | 11:01 AM
Shrike6's Avatar
Shrike6
Somba master
Ben,
Maybe you can connect your code reader while driving home and, if it happens again, you might catch something. If you can, maybe you could swap batteries with your neighbor and see what happens.
Old Jul 22, 2011 | 02:36 PM
truckplay's Avatar
truckplay
i had it happen to me on my 05. i traced it to an air leak at the coupler from my Varaam to the maf. I put a hose clamp on the coupler and it went away. it's been about a year now. I had no codes either.
Old Jul 24, 2011 | 03:34 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
I like the idea of connecting a fuel gauge and see if the pump cuts out.
