Seat Memory and Exploding Driveshaft
Old Jul 18, 2011 | 11:06 AM
mariomark's Avatar
mariomark
Default Seat Memory and Exploding Driveshaft
The memory seat function on my fathers '10 GS seem to be not working some of the time. Some days it doesn't seem to work and is constantly having to be reset. Could he be opening the door too fast once the car is stopped? Anyone else have this problem?
And for the exploding driveshaft, some video from my last FF race;
http://www.youtube.com/watch?v=wp8JrDeAXEo
Old Jul 18, 2011 | 08:56 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Memory seat/Memory steering column problems are common.
Check all the connectors under the seat, and look for loose or pinched wires anywhere.
Re-set the positions, remembering that you have one set for fob #1 and another set for fob #2. Be sure he is in the correct conditions for the system, our A6 requires being in Park, manuals need the parking brake set (I think).
Finally, some C6's seem to have this as an unsolvable intermittant problem. On our 2009, it was intermittant and getting more frequent. Under warranty, the dealer checked all the connections and replaced the memory module. That fixed it for about two months, then it started up again. After about three more months, it fixed itself. No problems for the last 4 months. That sounds like a loose connection but we can't find anything.
"It's not a bug, it's a feature!"
Old Jul 18, 2011 | 09:08 PM
VET4LES's Avatar
VET4LES
Check this connectors. I zip tied them and made them tight.
These are under the drivers seat.
Old Jul 21, 2011 | 05:59 PM
mariomark's Avatar
mariomark
He put it in the shop, they said it needed a memory module and had to order one. They also said it would get here quicker if the customer would pay for faster shipping.
Old Jul 22, 2011 | 03:38 PM
Bill Dearborn's Avatar
Bill Dearborn
Hopefully, he didn't fall for that. If the part is in stock they can usually have it in one to two days. Just take the car home and wait for the part.
Bill
Old Jul 22, 2011 | 08:37 PM
glennhl's Avatar
glennhl
I really enjoyed the racing footage, but I have to tell you, when I saw that driveshaft explode I thought of Felipe Massa getting smacked by the spring. Be careful out there!
Old Jul 23, 2011 | 08:35 AM
mariomark's Avatar
mariomark
The car is back and working fine for now. The seat is remembering.
Yes, that shaft would not be nice to catch. When it finally hit the ground it did a high bounce. A '71 Brabham came around the corner and hit it square. It broke his front left suspension and cast aluminum pedal assembly. I've had all kinds of things bounce over my head in that car.
To Seat Memory and Exploding Driveshaft
