LS7 heads removal
Old Jul 19, 2011 | 01:22 PM
msd127's Avatar
msd127
Default LS7 heads removal
I plan to have the valve guides and exhaust valves replaced on my bone stock 2006 z06, I live in Canada so I want to remove the heads myself (I have the shop manuals but am not a mechanic) and send to WCCH is there any advice / caveats you would give to a do it yourselfer? Thnx
Old Jul 19, 2011 | 01:24 PM
choprfgr's Avatar
choprfgr
Keep everything clean - follow process - don't cut corners.
Old Jul 19, 2011 | 01:33 PM
staticki's Avatar
staticki
This is for an fbody, but the process is exactly the same
http://www.ls1howto.com/index.php?article=2
Old Jul 19, 2011 | 06:26 PM
DSOMC6's Avatar
DSOMC6
Good choice using WCCH. They just rebuild my heads and do excellent work.
When removing the head bolts, leave the head bolts screwed in about 1/2 inch then lift the head up so the excess coolant drains out (less coolant in the bolt holes). Then make sure you use q-tips or rolled-up paper towels to get all the coolant out of the head bolt holes. This is important so you don't end up with a cracked block.
Remove all hardware from heads..ie: coolant plugs, sensors, fittings etc. Sometimes these parts don't make it back to the owner and can be a pia because GM seldom stocks this stuff. Take pictures so you remember where everything goes.
Use ARP head bolts instead of TTY oem ARP's are worth the few extra $$.
Old Jul 19, 2011 | 08:44 PM
msd127's Avatar
msd127
Default LS7 head removal
Thanks for the advice, am making careful note of this. Where can I buy ARP head bolts, your the second person to mention this? Thank you
Old Jul 19, 2011 | 08:46 PM
msd127's Avatar
msd127
This is awesome, thanks for the info.
Old Jul 19, 2011 | 10:54 PM
DSOMC6's Avatar
DSOMC6
http://www.texas-speed.com/p-131-arp...04-blocks.aspx
You may also want to purchase an extra tube of molly grease ahead of time (apply a small amount to the bolts/washers). The small packet that ARP provides isn't really enough if you are a little messy like me.
Old Jul 19, 2011 | 11:03 PM
msd127's Avatar
msd127
Thank you
To LS7 heads removal
