Is this normal???excessive heat?
Old Jul 28, 2011 | 08:18 PM
autorennen's Avatar
autorennen
Default Is this normal???excessive heat?
I recently bought my first Corvette, it is a pre-owned 2008 base model with the Z51 package. I noticed that if I touch the part of the manual gearshift, just below the **** (by the metal ring which secures the **** to the stick and leather boot) that if feels hot, I also feel some heat in the center console. I know that the car chassis is low, and I am sitting right on top of the engine/transmission, but is this normal or should I bring it to the dealership to see if something is wrong.
Old Jul 28, 2011 | 08:24 PM
Kenny94945's Avatar
Kenny94945
Normal (unless the car has the exhaust modified poorly)
Do not put a chocolate bar in that center console!
Do a search,...there are tunnel plates and heat liners to reduce the heat.
This is a known complaint.
Old Jul 28, 2011 | 08:40 PM
taken19's Avatar
taken19
Track Junky
I actually put some Aluminum AC duct tape on my stock tunnel plate the last time I dropped the drivetrain and it seemed to make a difference. A roll costs about $10. It may be worth the effort since it's significantly cheaper than an aftermarket tunnel plate.
I perfer the cheap and easy. Just my 2 cents.
Sean
Old Jul 28, 2011 | 09:05 PM
autorennen's Avatar
autorennen
Thanks for the responses, as long ad it's normal, I'm not too worried about it.
Old Jul 28, 2011 | 09:15 PM
Vette_DD's Avatar
Vette_DD
It varies from one C6 to another. Some heat in some of mine - hardly any in others.
Old Jul 28, 2011 | 11:59 PM
Boomer111's Avatar
Boomer111
Another by product of the heat barrier tunnel plate is the xtra rigidity it offers.
Old Jul 29, 2011 | 12:23 AM
TTZ06VETTE's Avatar
TTZ06VETTE
Get the insulated tunnel plate. Well worth the investment. My inside cockpit temps dropped significantly...
Old Jul 29, 2011 | 12:56 AM
haljensen's Avatar
haljensen
You are seated behind the engine. The transmission is attached to the differential near the rear wheels.
Old Jul 29, 2011 | 07:50 AM
Gering's Avatar
Gering
Tolero Apto Victum
Sir, take a look at this item. http://forums.corvetteforum.com/c6-c...insulator.html I installed it in my 07 Z51 A6 and like it a lot.
Old Jul 29, 2011 | 07:52 AM
Gering's Avatar
Gering
Tolero Apto Victum
Deleted.
Old Jul 29, 2011 | 10:21 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Originally Posted by haljensen
You are seated behind the engine and directly above the exhaust. The transmission is attached to the differential near the rear wheels.
a small addition to your post which is correct, and which also accounts for the heat in the car at several points/places...
Old Jul 29, 2011 | 01:01 PM
ejbarre's Avatar
ejbarre
The Tunnel Plate w/Thermal abs from Elite Enginneering & the insulation kit from Crazy Cowboy were 2 of the best mods for my C6. Got rid of the heat & some of the drone from my Flowmaster exhaust.
http://forums.corvetteforum.com/c5-p...tic-vette.html
Good Luck.
Old Jul 29, 2011 | 03:24 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You can significantly reduce cabin heat and some road noise by installing some thin insulation on the floor and tunnel.
Heres what I did. I used some thin heat duct insulation called FROST KING and some foil covered bubble wrap called REFLECTEX (SP?). It made a big difference!
The insulated tunnel plate also helps some. I have the entire drive train out for some work and I plan on installing the frost king on the inside of the tunnel before i reinstall the drive train!
To Is this normal???excessive heat?
