Coolant Recommendation
Old Jul 28, 2011 | 10:28 PM
TSLAVette's Avatar
TSLAVette
Default Coolant Recommendation
Switching thermostat this weekend ...
First, how much coolant am I going to lose on an LS3? Second, I've heard not so favorable reviews on the OEM Dexcool ... what recommendations do my Forum brothers have? I'm not planning a complete flush ... so, how much will I need and any issue(s) in mixing new with the OEM stuff???
Old Jul 28, 2011 | 10:41 PM
clakian's Avatar
clakian
No problems 40,000 miles. Added wetter water. It helped alittle
Old Jul 28, 2011 | 10:46 PM
Wayne88's Avatar
Wayne88
I just did a complete coolant flush on my 2006, it's 5 1/2 years old and there was no problem with the OEM Dexcool.
There once was a problem with Dexcool where it gummed up, but I understand that was remedied about 10 years ago. Dexcool 50/50 mix is what to use.
Old Jul 29, 2011 | 05:24 AM
Swiftrider08's Avatar
Swiftrider08
I have had the stat out twice now on my LS3. I use a cat litter pan (they are low) and slide it under the radiator drain. Drain there first and then slide the pan under the stat housing. Lossen the bolts to the stat housing and pull it back slightly and let the coolant drain instead of just gushing out. Remove housing, change stat, bolt back up. I then use a paint filter and pour the fluid back in. I have a full jug of Dexcool that I have not even had to open yet as I did not loose hardly any coolant using the large litter pan.
One tip on chaning out the stat - don't take the lower hose off the stat housing. Just remove the two bolts and pull back. Much easier to do this way. Make sure the tab on the gasket is lined up with the housing when you put back.
Seems like a major job, but in reality it will take you maybe 10 minutes from start to finish. Make sure car is sitting flat when you put the fluid back in.
Old Jul 29, 2011 | 07:53 AM
Gering's Avatar
Gering
Tolero Apto Victum
It may help prevent corrosion.
Old Jul 29, 2011 | 09:08 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Stick with the GM Dexcool. There are no issues with it. You run into problems when you mix Ethlyn Glycol based anti freezes with Dexcool and end up with a gelatin-like mess in your radiator and motor. Use a 50/50 mix of Dexcool and distilled water. A bottle of Watter Wetter won't hurt.
Old Jul 29, 2011 | 10:18 AM
Bill Suttie's Avatar
Bill Suttie
THERE IS NO PROBLEM WITH '' DEXCOOL''! The past bad history was engine specific and was not the fault of Dexcool. Replace it every 5 years or 150,000 miles which ever comes first and enjoy your car.
Old Jul 29, 2011 | 10:19 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
use dexcool, the real stuff.
one of the issues w. dex was if it got low in the reservoir, it tended to foam up a bit and not work as well at cooling. idea/key is to get it right w. no air pockets in cooling syst., and correct level. just watch the level for several times after you drive and cool off.
Old Jul 29, 2011 | 06:04 PM
haljensen's Avatar
haljensen
Use Dexcool. Treat your wallet right and don't buy the 50/50 premixed, it ends up costing a lot more.
Old Jul 29, 2011 | 06:39 PM
TSLAVette's Avatar
TSLAVette
Guys, thanks much! Where do you buy your "real stuff" Dexcool???
Old Jul 29, 2011 | 06:51 PM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
I get mine at Walmart. It's Prestone Dex-Cool. Silver 1 Gallon plastic container with an orange cap. Has the blue GM label at the top. Says "GM Dex-Cool Approved". It's the right stuff
Old Jul 30, 2011 | 06:19 AM
Swiftrider08
You can only get the "real stuff" at your GM dealer, not Wal-Mart!
Old Jul 30, 2011 | 08:13 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I agree with Michael, swiftrider, above, but there is also "licensing" of Dex to Prestone and others (see below quote). It gets a bit more expensive at the GM dealer, but for sure it's the real thing.
per this fr. Prestone site (http://www.prestone.com/products/print/411?popup=1):
"Technology
This patented formula has a concentrated blend of premium long-lasting inhibitors for extended performance, protecting against temperature extremes and the ravages of rust and corrosion. Prestone® Dex-Cool® Approved Antifreeze/Coolant has been approved by General Motors to be licensed as a DEX-COOL(r) product under the GM 6277M specification."
Old Jul 30, 2011 | 08:22 AM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
The reality is that most coolants are made by the same manufacturer and re-badged. The Prestone Dex-Cool meets GM specs and I have been using it for years with no issues whatsoever. If you want to pay more for the same coolant, go to your stealership.
Old Jul 30, 2011 | 11:40 AM
Bill Suttie
The statements inposts 11, 13 & 14 are correct. As long as the lable says "Dexcool Approved" and meets GM 6277 M it is the real stuff.
Old Jul 30, 2011 | 06:15 PM
StKnoWhere's Avatar
StKnoWhere
A little more than a gallon came out for me. I captured in a pan, filtered and reused most of it.
Old Jul 30, 2011 | 06:17 PM
Swiftrider08
The big question is, did the OP get his new thermostat installed yet?
Old Jul 30, 2011 | 10:12 PM
TSLAVette's Avatar
TSLAVette
Not yet, but I have the goods thanks to you guys!
Waiting for my Corvette mechanic to get back in town - doing sways, ceramics & fluid, t-stat. I just had surgery and can't wrench or wiggle in tight spaces.
To Coolant Recommendation
