Zero Oil Pressure
Old Aug 16, 2011 | 09:10 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Melling 10296. Flows 18-23% more than stock (depending on who you ask) and comes with a higher pressure relief valve : http://www.lingenfelter.com/mm5/merc...egory_Code=C54
I elected to not crack it open and I don't have any other pics of it but there are some here: http://www.jegs.com/i/Melling/689/10296/10002/-1
Old Aug 16, 2011 | 09:20 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
You didn't elect to slip in a G6x3 while you were at it, did you???
Old Aug 16, 2011 | 09:36 AM
taken19's Avatar
taken19
Track Junky
Agreed. With all that work, it would be silly not to evaluate a cam at that point unless you already had one. It's only about another hour of work to get a new cam in there.
Old Aug 16, 2011 | 09:46 AM
5 Liter Eater
St. Jude Donor '11
Agreed. It was about two steps away from a cam swap. If I had a stock cam I surely would have swapped. I already have the ECS blower cam and am happy with it though so there was no need. I probably should have replaced the balancer with an Innovators West unit though.
