Going to E85
Old Aug 10, 2011 | 12:43 PM
5LEEPER's Avatar
5LEEPER
Default Going to E85
Are 39lb injectors big enought for E85?
Old Aug 10, 2011 | 12:51 PM
FloydSummerOf68's Avatar
FloydSummerOf68
I'm not sure exactly what you mean in the first question.
39lb injectors I don't think are large enough (I assume this is in a Z06). After tuning and E85 you'll be needing more injector
Old Aug 10, 2011 | 01:09 PM
5LEEPER's Avatar
5LEEPER
how about a 50lb injector?
Old Aug 10, 2011 | 01:16 PM
FloydSummerOf68
50lb would probably be bare minimum for a bone stock Z
http://www.rceng.com/technical.aspx
Multiply estimated crank horsepower by and additional 30% to compensate for E85
Old Sep 8, 2011 | 10:41 PM
5clubLS2's Avatar
5clubLS2
How about for a LS2, what size would i need?
Old Sep 8, 2011 | 11:04 PM
jpee's Avatar
jpee
Old Sep 8, 2011 | 11:06 PM
FloydSummerOf68
Well I'm putting FAST 57# in my car for my cam-only build to run on E85 and I wouldn't be comfortable going any smaller.
Old Sep 8, 2011 | 11:14 PM
5clubLS2's Avatar
5clubLS2
humm, if you were to do the heads what would you go with?
Old Sep 9, 2011 | 08:35 AM
FloydSummerOf68
It's very easy to calculate: http://www.rceng.com/technical.aspx
Go to the bottom of the page and change the crank horsepower.
I take RWHP + 65 for my auto for drivetrain loss and then multiply by 1.3 for the added fuel needed from E85.
You can also change the duty cycle you wish to have. Most will recommend not exceeding 80% duty cycle, but up to 90% SHOULD be ok.
For my car with an estimated 460-465rwhp after my cam swap would need 54.61lb injectors for 80% cycle.
Assuming 500rwhp for moderately aggressive heads/cam build the 57# injectors should still be ok.
Old Sep 9, 2011 | 02:01 PM
5clubLS2's Avatar
5clubLS2
To Going to E85
