just recently purchased a 2007 ls2 and attained the mod list from the previous owner and was just wondering what i should be looking to expect with a good tune car seems to be running a bit rich now w slight hesitation off the throttle at low rpm
mods are fully ported heads,bullet racing cams with 632 lift a 252 264 duration ,comp push rods , patriot retainers
comp cam gold rocker arms , titanium valve springs and retainers
kook longtube headers,slp loudmouth exhaust,custom x pipe, haltech intake
im not positive on the cam specs thats what i was told and no i dont believe it is because it supposedly was dynoed before and put down around 455 but im thinking that was w a bogus tune.
Need more info... Stock ported heads or aftermarket? That cam is HUGE for an LS2, probably has one hell of a time idling. What is the LSA? As an example, here is what I have:
LG 1-3/4" street series headers, no cats
230/234 114+2 cam (.598/.612 lift)
CNC'd stock heads
FAST 102
ported TB
WCC hurricane CAI
Stock bottom end
Borla Touring axleback
My car idles at 900 RPM with minimal lope. Made 468/445 on a Mustang dyno (485/440 on a Dynojet) at 24 degrees of timing and 12.7 AFR.
If you have stock displacement I would say that cam is way oversized for your application. It's probably worht doing more research to verify the cam specs.
the car idles at around 1k rpm and from inside the car has a pretty significant shake to it and as far as the heads what i put down was all the info i got im going to try and call the dealership i bought the car from today and get in touch with the previous owner i have a tune scheduled for monday at rpm in raleigh nc also teh car tends to buck alot while cruising in 5th -6th gear at lower rpms
