Micro Switch...
Old Aug 12, 2011 | 04:54 PM
FastGhost's Avatar
FastGhost
Default Micro Switch...
Question.
Can the same micro switch used to turn on the methanol under boost be tapped into to turn on the fuel boost pump? Or does the fuel booster pump need it's own micro switch?
Old Aug 14, 2011 | 01:35 AM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
It would be fine as long as you are using it to supply voltage to the boost-a-pump relay and not supplying voltage to the boost-a-pump itself.
Does your meth inj. not have it's own controller?
