Tips for Avoiding Wheel-Hop at Launch?
Old Aug 13, 2011 | 10:07 AM
SuperSonicDave's Avatar
SuperSonicDave
Cruising
Default Tips for Avoiding Wheel-Hop at Launch?
Hey guys, new member here, my 1st Vette, a 2011 Coupe, base, 6 spd manual.
I'm still breaking the car in for now, but once that is complete and I have some more seat time I do plan to hit the track for some fun at the strip.
Most of my drag racing has been with cars with live axles. My buddy has a 2008 C6 and says he has lots of issues with wheel-hop at launch with the IRS.
Any tips/tricks to maximizing launch? I read thru Ranger's threads and his site (good stuff).
Any specific things I can do to avoid wheel-hop at launch? My local track is Atco, which is sea level, and often hard to "avoid" the water-box they way they have it set up, etc.
Thanks in advance.
Old Aug 14, 2011 | 02:59 PM
Fuego's Avatar
Fuego
Never had any problem with wheelhop in my base 08. The Z51 suspension is the main culprit for wheel hop with its lack of weight transfer on launches. At least in my experiences it has been the main difference between a friends z51 c6 that hops and my 08 that doesn't.
Old Aug 14, 2011 | 08:56 PM
SuperSonicDave
Cruising
Interesting, thanks. I have the base suspension... maybe that'll help with the weight-transfer at launch, etc....?
Old Aug 14, 2011 | 09:56 PM
HANNY's Avatar
HANNY
stock runflats and alot of miles???? if so the tires could be an issue. they seem to get kinda hard/glazed looking then might want to replace with a softer tire. I havent heard of to much wheel hop with the vettes,,,,, i would also check the sway bar for looseness ,,,,maybe a bushing bad? good luck with it, paul
Old Aug 15, 2011 | 10:49 AM
jthurik's Avatar
jthurik
I would look at the PFDAT transmission mounts as the stock mounts are huge cause of the wheel hop.
Old Aug 15, 2011 | 10:58 AM
Crowhater's Avatar
Crowhater
Originally Posted by jthurik
I would look at the PFDAT transmission mounts as this is a huge cause of the wheel hop.
Excuse me but are you trying to say the PFDAT mounts cause wheel hop? My understanding is that the PFDAT mounts cure wheel hop.
Old Aug 15, 2011 | 11:01 AM
jthurik's Avatar
jthurik
No they fix the wheel hop was just typing too fast. Using the PFDAT tranny and motor mounts will pretty much make the hop go away.
Old Aug 15, 2011 | 11:13 AM
SuperSonicDave
Cruising
Great info. Thanks guys.
Old Aug 15, 2011 | 01:29 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
This......and maybe some softer tires. I never had trouble in 1st gear, I guess, I wasn't coming off hard enough. My problem was when I went to 2nd, but when I put the NT05's on the rear it took care of that problem.
It's not always that easy, tho.
Larry
Old Aug 16, 2011 | 02:50 AM
tarik916's Avatar
tarik916
Make sure your reduce your tire pressure. I usually run with 25psi and don't have any problems. I made 1 pass with 36PSI and the wheel-hop after the 1-2 shift was pretty severe.
My experience may be a little difference since I have Hancook V12's tires and Bilstein Sport Shocks.
Old Aug 16, 2011 | 08:52 PM
corvet786c's Avatar
corvet786c
I have bilstein hd shocks and aftermarket non run flats and still get wheel hop on trying to smoke the tires for launch. The link below use urethane mounts and this week they are supposed to have tranny mounts with a package deal. I would get solid mounts though to much vibration.
Have you ever looked at the trans mounts under the car. I felt mine and they were soft and mushy. The trans mounts are directly connected to the differential. I can understand why this would cause hop bouncing.
http://hinsonsupercars.com/p-1285-hm...5c6gtorx7.aspx
Old Aug 16, 2011 | 09:50 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Don't bother racing on runflats. Spinning your tires is no fun and the risk of wheelhop and rear end damage is high.
I have 445 passes on my z51 car and I never get wheel hop. I attribute that to using drag radials at 18 psi...the side walls have some give and absorb the shock.
Old Aug 17, 2011 | 03:12 PM
PRE-Z06's Avatar
PRE-Z06
I agree with Joe, if you're serious about drag racing get some DR as they'll be easier on parts if not launched super aggressively as they absorb drivetrain shock and will save you from burning up your street tires. This is not a car you want to just rev up and pop the clutch being an IRS, if it starts to hop whether on the street or track get out of it asap. I've run different suspension(Z51/Z06/ Bilstein, springs/sway bar/shocks), multiple tires (Hoosier, M/T, Pirelli, Michelin, Goodyear, Hankook, Kumho) at different psi and have had it hop depending on the surface. I don't think there is a cure all, but many of the things mentioned will help lower the chances of it happening. Good luck at the track!
Old Aug 17, 2011 | 04:19 PM
TMyers's Avatar
TMyers
Please read this:
http://www.mc2racing.com/tech/20061012a/index.html
Old Aug 17, 2011 | 04:39 PM
Vegas Panton's Avatar
Vegas Panton
Default Wheel Hop
I had wheel hop with my 09, Z51, C6, manual with Nitto DR's. at 18 psi I switched to BFG DR's at 18 psi. It made no difference (as noted in the above post). When I use the exact same BFG's on my 02, Z51, C5, manual I have no problems. Finally, I changed the Z51 shocks to C6Z06 shocks .Problem solved
Old Aug 18, 2011 | 07:36 PM
V8ANGER's Avatar
V8ANGER
Old Aug 19, 2011 | 09:41 PM
SuperSonicDave
Cruising
Yeah, if I start going regularly, I have had good luck in the past with BFG DR's. Seems the shocks make a difference, and not the way I anticipated. I have the base suspension, and figured the weight shift would help with launch with the softer shocks, etc...
I'm assuming the Z06 shocks are stiffer in every regard....?
Old Aug 19, 2011 | 10:03 PM
SuperSonicDave
Cruising
Originally Posted by TMyers
Good read, thanks.
Anyone got any links to bushings that'll solve the issue in the C6??
Thanks again!
To Tips for Avoiding Wheel-Hop at Launch?
