Battery Voltage Question
Old Aug 18, 2011 | 02:18 PM
Rockstar C6's Avatar
Rockstar C6
Default Battery Voltage Question
Hi, I'm hoping you guys can tell me if this is normal. I just had LG headers put in with a tune and ported the throttle body in my 2006 M6. Well, when I start her in the garage I noticed the running light and tail lights were flickering. Well, when it warms up and I take her on the road the flickering stops.
So as I'm driving down the road, my battery voltage on the DIC is about 14.0 to 14.1. And when I'm stopped at a red light it reads about 13.5 to 13.6. When I pull into the driveway and let it idle for a couple of minutes it DROPS all the way down to 11.5 to 11.8......... Is this normal?? or do I have an area of concern????
Any help would be appreciated. Thank you.
Old Aug 18, 2011 | 02:59 PM
Street Rat's Avatar
Street Rat
I have an auto trans Vette that was dropping volts in gear at idle after a tune. My tuner simply increased the idle speed and the problem went away. I would think that with the manual trans your idle would be set a bit higher.
Old Aug 18, 2011 | 04:28 PM
LS1LT1's Avatar
LS1LT1
That sounds pretty normal....
....but that does not.
11.5 - 11.8 seems a little low.
Old Aug 18, 2011 | 08:44 PM
don7790's Avatar
don7790
check your idle
Old Aug 19, 2011 | 01:47 PM
Rockstar C6
Can you tell me what my car should idle at? While just sitting in the driveway with the air conditioner on, it idles at 600 RPMs. Should this be higher?
Old Aug 19, 2011 | 06:40 PM
truckplay's Avatar
truckplay
check the cables at the battery, alternator and down at the starter. voltage should not drop that low, the computer doesn't like it.
To Battery Voltage Question
