Well here goes, my first header install.
Old Aug 21, 2011 | 05:39 PM
  #41
BAMAGOLFER's Avatar
BAMAGOLFER
St. Jude Donor '06-'10-'11
Street Rat total time was probably around 8-9 hours. BUT!!! I am by no means a mechanic and really took my time. In real time I started Friday about 9 AM and finished Saturday by 1-2 PM.
As I said before, having a lift and a friend helping would have greatly reduced the time.
Kelly
Old Aug 21, 2011 | 05:47 PM
  #42
Motorhead-47's Avatar
Motorhead-47
If I had known you were going to do this solo I would have been there!
Old Aug 21, 2011 | 06:18 PM
  #43
BAMAGOLFER's Avatar
BAMAGOLFER
Thanks Ken but I did have help. My wife was nagging...errr I mean supervising.
Old Aug 22, 2011 | 01:45 PM
  #44
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
When you dropped the stock manifolds and cats, how did you reach the electrical harness connectors for the rear O2 sensors which are up against the firewall and impossible to reach with manifolds in place? Did you remove the sensors themselves and then drop the manifolds & cats?
Old Aug 22, 2011 | 07:49 PM
  #45
BAMAGOLFER's Avatar
BAMAGOLFER
Sub Vette I had to use a sort of long flat blade screwdriver to release the little blue tab that locks the other tab that you release to pull the connectors apart. Just takes some patience.
As promised here are the before and after sound clips. Sorry about the before clip it's not my greatest moment in videography.
Before:
After:
Hope this gives you a good idea of how great it sounds.
Kelly
Old Aug 22, 2011 | 08:07 PM
  #46
upsta8NY's Avatar
upsta8NY
Great job man sounds so awsome.
Old Aug 22, 2011 | 08:41 PM
  #47
victorf's Avatar
victorf
To the OP.
Is the Passenger's side pipe outlets need adjustment or is it just an optical illusion?
Old Aug 22, 2011 | 09:22 PM
  #48
BAMAGOLFER's Avatar
BAMAGOLFER
No optical illusion. That's part of the tweaking I need to do.
Old Aug 22, 2011 | 09:39 PM
  #49
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Congratulations on a job well done, thanks for sharing the videos, nice touch with the before and after. Oh, car looks beautiful
John
Old Aug 22, 2011 | 10:10 PM
  #50
StKnoWhere's Avatar
StKnoWhere
Nice!
Did you do your own NPP install?
If so, how did the install difficulty compare?
Old Aug 22, 2011 | 10:20 PM
  #51
BAMAGOLFER's Avatar
BAMAGOLFER
Thanks guys. The NPP install was pretty easy because I went over to a frinds house and we used his lift. So you ask why didn't I go there for the headers? Well it was mostly due to the time involved.
Old Aug 22, 2011 | 10:32 PM
  #52
matt_lowry123's Avatar
matt_lowry123
St. Jude Donor '11
Wow good job man!!! That sounds wayyyy better!!
