No Passanger side reverse light?
Old Aug 19, 2011 | 11:00 AM
mskvettefan's Avatar
mskvettefan
Default No Passanger side reverse light?
I just purchased a 2008 Convertible and noticed that the passanger side reverse light is out. I did not check the bulb first, figuring, it's a perfect opportunity to change over to LED super bright bulbs.
I climbed under and pulled the bulb only to find the bulb is fine, I chaged it out anyhow with the LED but it still does not light.
The drivers side lights fine, any suggestions as to what to look for or how to trouble shoot this passanger side?
Old Aug 19, 2011 | 11:18 AM
LEAVINU's Avatar
LEAVINU
I'd use a gauge to check the plug for power first. Have someone put the car in reverse with the car on and see if the plug registers any voltage.
Old Aug 19, 2011 | 12:34 PM
Surf2602's Avatar
Surf2602
Lol I have LEDs and I have just told my passenger reverse light is out too. Haven't checked it out yet though
Old Aug 19, 2011 | 12:35 PM
Surf2602's Avatar
Surf2602
And it's an 08 vert
Old Aug 19, 2011 | 12:59 PM
mskvettefan
Correct, and 08 Vert...
Only two wires to these lights and I believe they likely run from one side to the other and one is a ground, correct? Perhaps I have a bad ground, but how the heck do you see up in there?
To No Passanger side reverse light?
