Air conditioner problem, Any ideas?
Old Aug 19, 2011 | 11:31 PM
VictoryVette's Avatar
VictoryVette
Default Air conditioner problem, Any ideas?
I searched the forum but have not found any answers so im hoping someone here can help before I have to go to the dealership. While sitting idle at the post office yesterday the air conditioner began blowing hot air, after i pulled back out on the roadway the air conditoner began blowing ice cold again. It has blown warm in the past while going down the road but always comes back ice cold again really quickly. I checked the coolant level with a gauge and it shows fine but it sounds like the compresser kicks off and on. turned off the car and restarted it and ice cold again. Any ideas? Im not sure if its the compresser or the hvac control unit or maybe something else? I have had the flashing numbers on the hvac control unit a long time ago leading me to believe its that but im not sure. Any help would be greatly appreciated before i go throwing money at gueses.
Brandon
Old Aug 20, 2011 | 12:23 AM
Luster's Avatar
Luster
You said you checked the coolant level. Did you mean refrigerant level?
If so, you might also want to check your engine anti-freeze/coolant. If it's low, it can cause A/C to blow hot air.
Old Aug 20, 2011 | 01:36 AM
VictoryVette
Sorry I meant that I checked the refrigerant, any other ideas?
Old Aug 20, 2011 | 01:51 AM
C7&7's Avatar
C7&7
Are the fans running? Sounds like they're going off. Has the car ever been tuned and the temps for fan enable toyed with?
Old Aug 20, 2011 | 01:54 AM
C7&7's Avatar
C7&7
Btw. My car has done this a few ties but it's the actual hvac controls that turned it off. I think it happened when my phone rang believe it or not. I just turned it back on. Really sounds like the fans. Driving would mask fan issues
Old Aug 20, 2011 | 02:13 AM
TMyers's Avatar
TMyers
Have the clutch checked. A friend just lost his clutch at the track a few weeks ago. Prior to that it was doing just what yours is.
Old Aug 20, 2011 | 10:17 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The software/firmware is designed to start shutting things off if the voltage level drops significantly. You might want to monitor the battery voltage if this happens again. How old is your battery?
Old Aug 20, 2011 | 10:47 AM
C7&7's Avatar
C7&7
Great point!
Old Aug 20, 2011 | 11:55 AM
Swampthang's Avatar
Swampthang
What is your air temp. gauge doing. If it gets dirty or starts going out it will indicate a low temp. <40 and the compressor will shut off.
Old Aug 20, 2011 | 12:36 PM
VictoryVette
The battery is about 3 months old and seems to be doing great, car is an 05 auto so couldn't be the clutch. The temp reading seems to be ok I have in the past had it say the wrong thing and not blow correctly but right now it seems to be right on. I'm sitting at prep boys right now letting them run a diagnostic on the ac system. If nothing else for 30 dollars maybe they can tell me what is working and whats not. Ie: compressor, correct refrigerant level.. Heres hoping!
Old Aug 20, 2011 | 01:23 PM
skamp's Avatar
skamp
Have you see this thread? Some 05's shipped with too much R134.
http://forums.corvetteforum.com/c6-c...e-factory.html
Steve
Old Aug 20, 2011 | 02:50 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I see your in Texas....and you know how hot it is down here right now.
I can tell you from daily driving mine in the heat the last few months....it has done similar to me.
Generally leaving the shop in the afternoon it will take it a little bit to cool off but as long as I'm running down the road it stays cool, and most of the time auto/re-circ mode. If you pull it out of that into fresh air mode it will warm up slightly.
Sitting in traffic on the tollway or side streets for long periods of time it will start to warm up. Only time I have had it blow warm on me was running the car a bit harder, and it will shut off WOT of course, and also if the car starts to run to hot coolant temp wise (say 225+). If the car is hot and it can not suck in enough air to cool off the condenser and the radiator it will shut the A/C off. As others have said as well there is a voltage/stall saver that will kill items to protect battery life and it will also kill the A/C and/or alternator to keep the car from stalling.
Old Aug 20, 2011 | 05:26 PM
dbradley's Avatar
dbradley
Originally Posted by VictoryVette
an 05 auto so couldn't be the clutch.!
He's probably talking about the compressor CLUTCH........
Old Aug 20, 2011 | 07:43 PM
dgrant3830's Avatar
dgrant3830
Yes, it will kill the radio, nav(I think), certainly the HVAC and other things but never the alternator.
Old Aug 21, 2011 | 11:35 AM
m R g S r's Avatar
m R g S r
Check the fan connector plug. If it is melted it may not be controlling the fan correctly, and when you start driving the airflow across the condenser cools things down, hence the warm condition when stopped but not while driving.
Old Aug 21, 2011 | 12:11 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Default A/c problems
What did the folks at PEP BOYS say. They should have checked the Charge High & LO Pressures when the compressor is running. From what I am hearing here it seems like a intermittent here. There are several things that will make the Compressor drop out. Unfortunately they dont show up as cel's but as conditions that go away when the sys returns to normal.
Can you tell me this.
1. When you get the hot air does the a/c light and fan indicator turn off ?
2. When the warm air comes and you pull over can you hear the fan running ?
Old Aug 21, 2011 | 05:23 PM
mlsins's Avatar
mlsins
I had this happen once. Shop replaced the high pressure switch and the problem was fixed. Good luck !!!
Old Aug 21, 2011 | 08:42 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Steve
If you've got an 05 I'd just about guarantee this is the issue. I had this exact issue on really hot days. There's a overpressure switch in the ac circuit that kicks off the compressor on really hot days.
Dealer started to fight me about it until I printed out the tsb and once they did the work, it's been fine for 5 years now.
Old Aug 27, 2011 | 11:08 PM
Mike's LS3's Avatar
Mike's LS3
Recently, I have experience the A/C all of a sudden blow warm air and the recirculation light would go off. I would press the " no a/c fan only " button on and off with no difference in temp. I then turned the A/C off, waited a few minutes and turned it back on and it worked. This occurred during 90 degree F temps, freeway driving, cooling fluid full, fan working, engine coolant temps 192- 198 and no other issues. Additionally, I have no battery issues or voltage drop issues, stock tune, no mods. It sounds like there is a faulty relay switch or pressure switch that is faulty? Thanks for any suggestions or help!
To Air conditioner problem, Any ideas?
