Axel Nuts
Old Aug 24, 2011 | 08:39 AM
Allspice56's Avatar
Allspice56
Default Axel Nuts
Two quick questions. When tightening axel nuts on the C6 does 1) the vehicle need to be raised and 2) the torque is set at 140 ft-lbs with #272 Loctite?
Many thanks!
Allspice56
Old Aug 24, 2011 | 10:53 AM
RicK T's Avatar
RicK T
First, you don't want to "re-torque" the existing nuts. There is a risk of stretching and breaking the spindle. Remove the existing nuts and install new ones using the below procedure. And no, the car doesn't have to be raised.
Correction
Replace the left and the right wheel drive shaft nut following the procedure below.
1. Remove wheel center cap and existing nut
2. Apply Goodwrench # 12345493 (also known as Loctite 272) on threads in area where nut finally seats
3. Install new nut (p/n 10257766)
4. Torque nut to 190Nm (140 ft-lb), static
5. Allow 24 hours cure time.
6. Install the center cap to the rim.
Important: The vehicle should not be driven for 24 hours following the repair in order to allow the thread lock to cure.
Parts Information
Part Number.....10257766
Description......Nut
Qty................2 (one per side)
Update 9/13/2007
Old Aug 24, 2011 | 11:55 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Rick-
Where did you get that bulletin copy?
My car had bulletin 07-04-95-001A performed on 11-24-2009.
Most of the previous copies I've seen say 160 ft-lb, which was apparently an error and reduced to 140 ft-lb at some point. I'm trying to figure out how much they tightened mine, mine might be over-torqued. Which might or might not be a problem some day.
Thanks!
Old Aug 24, 2011 | 03:23 PM
Kenny94945's Avatar
Kenny94945
FWIW....+1 on using new nuts.
Also, double nutting would stop the loosening issue, yes?
Will someone will post the current TSB for us all?
Old Aug 25, 2011 | 12:38 PM
Allspice56's Avatar
Allspice56
Rick T,
Many thanks for the response!
Allspice56
Old Aug 25, 2011 | 03:14 PM
glennhl's Avatar
glennhl
Every time I see this thread's title I chuckle. I can envision some German guy named Axel and I wonder what is up with his nuts?
Axle, not Axel.
Old Aug 25, 2011 | 09:28 PM
Gearhead Jim
St. Jude Donor '13
Axle, not Axel.
No, you've got it all wrong.
They are talking about nuts from the axel tree, very tasty.
But very tough and sometimes a little greasy.
Old Aug 27, 2011 | 04:17 AM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
What size socket do I need?
Old Aug 27, 2011 | 06:03 AM
SpinMonster's Avatar
SpinMonster
On my last axle, I used locktite with 100ftlbs. I marked the position of the nut to axle with a black magic marker. It has never moved in 3 years. The first 2 axles broke within a few days of each other. The first broke when I asked Roy at Cartek to check it. He tightened it and it broke that night.
Tqing to 140 or 160 is rediculous and pulls along the spindle weakening where the spindle meeds the hub. I broke two axles going to 160. The second axle was TQed and marked and still came lose with the mark unmoved. To clarify: the axle nut was at 40ftlbs with the black mark unmoved, hence something stretched. Draw your own conclusion.
Nothing is going to fall off the car even if the nut was to come off. If its at 40ftlbs with locktite, its not going anywhere. The car can function with no nut on at all so dont get hung up on what the TQ value is. If that black mark doesnt move, dont put a TQ wrench on it. If the axle breaks however, it can swing around and lock up your rear wheel and take out other suspension parts. Which scenario do you like better?
Old Aug 27, 2011 | 10:11 AM
Bill Suttie's Avatar
Bill Suttie
Default axel nuts
I agree with Spinmonster. DO NOT GET TORQUE HAPPY WITH THE REAR AXEL SPINDLE NUTS.
Old Aug 27, 2011 | 03:54 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Axle, not Axel.
Any relation to Axel Foley?
Old Aug 27, 2011 | 04:01 PM
Keith N's Avatar
Keith N
It was a 33mm socket for my 2006 Z06. I bought it at Kragen Auto Parts.
Old Aug 27, 2011 | 05:36 PM
Gearhead Jim
St. Jude Donor '13
Same here.
But that wouldn't fit on our 2009, needed 34 mm from Pep Boys.
Old Aug 28, 2011 | 11:25 AM
chasboland's Avatar
chasboland
I used a 1-5/16" socket that fits fine although it is slightly larger than 33mm. No need to drop 20 bucks if you don't have to.
To Axel Nuts
