Engine Light/fuel door
Old Aug 25, 2011 | 09:41 AM
kompressor830's Avatar
kompressor830
Default Engine Light/fuel door
My engine light is on and the code is saying something about the fuel evap. The fuel door will not stay closed either. Any way to resolve this issue?
Old Aug 26, 2011 | 05:37 PM
dbradley's Avatar
dbradley
If you try to 'top off' the tank when filling, raw fuel will get into evap system and cause a light. When it 'clicks' off DON'T add more fuel. Should clear when you burn off fuel and the excess evaporates from canister. As for door, probably needs adjustment.
Old Aug 26, 2011 | 08:32 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
A long shot, but-
Fuel cap on crooked, or damaged; so it's sitting a little high? That might turn on the light and also prevent the door from closing.
To Engine Light/fuel door
