e-force supercharger #1572 need some help !!!
Old Aug 28, 2011 | 03:13 PM
ttfanatic's Avatar
ttfanatic
Default e-force supercharger #1572 need some help !!!
Looking for a little guidance on two parts that came with the 1572 kit and are not anywhere listed or mentioned in the step by step install guide, One is a vacuum or breather hose with a T fitting on the and and the other is a small bracket. All other parts and PCV/breather hoses are connected where they belong. I'm totally puzzled any suggestions will be appreciated.
THIS IS THE THREAD
http://forums.corvetteforum.com/c6-f...h-2-parts.html
Old Sep 6, 2011 | 05:26 PM
rsimons's Avatar
rsimons
Cruising
The bracket is for early ZO6s that don't have the oil cooler mounting bosses cast in to the oil pan. This is detailed in step 97 of the instructions:
http://www.edelbrock.com/automotive_.../1000/1572.pdf
The hose is for later ZO6s that have the second small tank for the dry sump. The hose tees into the hose running from the valve covers to the rear dry sump tank fitting, and runs down to the secondary tank. This is detailed in step 168 of the instructions (see link above.)
