Anyone running Comp LSR cam?
Old Aug 29, 2011 | 08:16 AM
COVERT GUY's Avatar
COVERT GUY
Default Anyone running Comp LSR cam?
Just doing a bit of research before jumping in. I've been looking into installing a Comp Cams LSR profile cam into my '05, just wanted to get some feedback on general driveability and power. Dyno graphs and track times would be appreciated also. Thanks.
Old Aug 29, 2011 | 09:47 AM
FloydSummerOf68's Avatar
FloydSummerOf68
What specs?
Do the LSR cams use LSL lobes? Or LSK? Or something different? I don't recall.
Old Aug 29, 2011 | 09:18 PM
COVERT GUY's Avatar
COVERT GUY
There are two that I am looking into the 227/235 and the 231/239 both are around .61X"/.62X" lift on a 113 LSA. I believe the LSR line up uses the Xteme Energy LSL lobes, not sure though.
Old Aug 29, 2011 | 10:05 PM
old motorhead's Avatar
old motorhead
The LSR cams use LSL lobes. Confusing? Go figure. I have two blower cams using the LSL lobes. Both custom grinds. The LSL lobes are supposed to be agressive while maintaining valve train stability. The LSK lobes are higher lift per degree of duration at the expense of valve train stability. Still a lot of LSK cams around, but they are getting harder to find. Folks are coming around to realizing you don't need stupid high lift to make power. .629 lift at 215 degrees duration on a well known blower cam...I can hear valve springs crying for mercy....
Old Aug 30, 2011 | 08:36 AM
FloydSummerOf68
Yeah, the LSL lobes are much better for valvetrain wear and tear than the LSK.
Either of those cams would be good, but you have to know how much cam you will be comfortable with. One will have about 5 degrees of overlap and the other almost 10.
If it's a manual car either would be pretty easy to drive in a daily driver application, but an auto would start to get temperamental at 10 degrees overlap. A lot of it has to do with the quality of tuning though.
The cam I'm putting into my auto C6 has 20 degrees of overlap, but it'll be more cam than most people want to deal with
If you want a suggestion for someone who is very good at tuning large cams in the Houston area let me know and I'll talk to you via PM. My car will be in for the cam swap in about 1.5 weeks. You're more than welcome to come check it out if you're interested.
Old Aug 30, 2011 | 09:01 AM
CTD's Avatar
CTD
My understanding is the LSK & LSL share the same lobe profile from .006 to .050 so the valve will close nicely, the difference is from .050 to .200 If you search over on LS1 Tech some good info.
I just removed a LSL 243/247 .623/.623 114+2 if that is something you might be interested in, it has about 300 miles. There will be AFR 8019 springs & retainers as well. 1/2 price
Old Aug 30, 2011 | 08:28 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
I am running LSL lobes, 235/239 on a 112 + 4 in my 2006 M6, this cam has 13 degrees of overlap and it is noticeable in certain driving areas. After my retune the car is running very well, the 2 cams you mentioned both look very good.
Old Aug 31, 2011 | 01:45 AM
COVERT GUY's Avatar
COVERT GUY
I may have to take you up on that.
Old Aug 31, 2011 | 01:48 AM
COVERT GUY's Avatar
COVERT GUY
Thanks for the offer, but I have a stock displacement LS2 (M6) and that sounds a bit more aggressive then a cam I personally would use for daily driving.
Old Aug 31, 2011 | 01:49 AM
COVERT GUY's Avatar
COVERT GUY
Thanks. Any track or dyno numbers from your combo.?
Old Aug 31, 2011 | 08:42 AM
FloydSummerOf68
Sure
Old Aug 31, 2011 | 11:20 PM
Neumonic2002
No track times yet, car put down 452/421 with a base tune. Should have new numbers in 2-3 weeks, just had the re-tune performed a few weeks back and the car runs noticeably stronger now. I am thinking the car will be closer to 460/425 now.
Old Sep 1, 2011 | 08:34 AM
COVERT GUY's Avatar
COVERT GUY
Nice numbers. Are you running the stock heads?
Old Sep 1, 2011 | 02:03 PM
Stang's Bane's Avatar
Stang's Bane
227/235 with full boltons and an unported fast 102. Car did 455 rwhp. No problems do far has good characteristics all the way around. That is through a 3.90 rear.
Old Sep 1, 2011 | 03:45 PM
COVERT GUY's Avatar
COVERT GUY
This is what I was hoping to hear, good numbers and good driveability.
Old Sep 1, 2011 | 05:28 PM
COVERT GUY's Avatar
COVERT GUY
Old Sep 1, 2011 | 07:06 PM
Neumonic2002
Yes, & Comp 26926 springs
Great numbers, what lsa did you use? I bet the manners are very good.
To Anyone running Comp LSR cam?
Old Sep 2, 2011 | 06:59 AM
Stang's Bane
113 +3. Manners are not bad at all. I really have no complaints with the cam...
Old Sep 3, 2011 | 04:27 PM
PRE-Z06's Avatar
PRE-Z06
Tell me about your goals and I can help get you into the right camshaft.
We have a cam install special currently going on and if one of our cams don't fit your needs, I can custom grind you one to your liking.
Old Sep 3, 2011 | 07:35 PM
COVERT GUY's Avatar
COVERT GUY
I am still a month or two out from doing it but, I will keep y'all in mind, Thanks.
