Oil temp LS3
Old Sep 6, 2011 | 04:20 PM
Bill Suttie's Avatar
Bill Suttie
Originally Posted by MPZ06
Thanks for all your answers and help!
Hope I can extend my stay here in the US.
Take care
Mirko
Mirko Enjoy your car when you get back to Germany. At least you can use a car in Europe not like in the US. Stay off those 3 lane suicide roads in France. Good luck Bill S.
Old Sep 6, 2011 | 05:10 PM
Ragtop 99's Avatar
Ragtop 99
Oil temp on highway (75 mls) goes 230 and easily continues towards 280 when using 5th and 4th.
Will take the car back to Germany and am concerned for high speed continuous driving on the Autobahn. I know that driving in lower gears here in the States to "simulate" more continuous higher revs is not a perfect comparison as the higher speed would bring more cooling.
On the other side the Corvette should be able to run for an hour or two at 140 to 180 mls/h.
Higher speed might provide more cooling, but higher speed means much more air resistance and the car burns a lot more fuel, generating significantly more heat. I don't like being near the edge when it comes to heat. Heat tends to spill over so eventually some of the heat makes into the coolant and then to the tranny (if the car has a tranny cooler loop in the radiator).
I'd add an oil cooler. Since Germany can get cold, look for one with a thermostat that restricts flow until 180* if you drive in the winter. I've seen them discussed on here.
Old Sep 6, 2011 | 09:31 PM
TripleAstyle123's Avatar
TripleAstyle123
It sounds high to me, but the Autobahn speeds can change alot compared to US-Hwy. speeds...... I would say if your oil level is RIGHT ON, then you should add an oil cooler!
Old Sep 6, 2011 | 09:39 PM
TripleAstyle123
It's 225 - 230.
cruising at 70mph in 80F temps....... seems high, I will have to check mine on the next run though....
Old Sep 6, 2011 | 09:53 PM
99c54me's Avatar
99c54me
Check that nothing is caught in front of the radiator air intake. A bag, plastic, bunch of pine needles, leaves, etc.
Old Mar 13, 2021 | 02:52 PM
N8 Wavy's Avatar
N8 Wavy
Originally Posted by hangtime204
280? That's a little too warm. Normal to hot temps for me are about 220-240 in my 08. What oil are you using?
Same here
Old Mar 14, 2021 | 11:05 PM
grpweld's Avatar
grpweld
A trans running 180* will last longer than 1 running 220*
Old Mar 16, 2021 | 04:42 PM
VVVROOMTX's Avatar
VVVROOMTX
A few things.
215 for trans temp is too high, and thats a fact. especially if its a regular occurrence. Heat kills the 6L80 and needs to be mitigated. Buying a transcooler will help tremendously. My trans temps, as long as I'm cruising on the high way at 65-75mph, stay under 180 even on a 100F day. Also heat shielding the transmission lines where they get close to the header or other heat sources help as well.
If your oil if getting up to 280 i would be concerned as well. An oil cooler would really help this as well. Also i would consider a thicker oil to prevent thinning at high temps. I run 5w-40 in my car due to the hot climate I live in.
Old Mar 16, 2021 | 04:43 PM
VVVROOMTX's Avatar
VVVROOMTX
Originally Posted by Bill Suttie
215 F trans sump temp IS NOT HOT.
215 is too hot and that is a fact. Heat is the number 1 killer of the 6L80 trans
