Oil temp LS3
Old Sep 5, 2011 | 08:35 PM
MPZ06's Avatar
MPZ06
Default Oil temp LS3
Have a 2011 Grand Sport automatic.
Oil temp on highway (75 mls) goes 230 and easily continues towards 280 when using 5th and 4th.
Will take the car back to Germany and am concerned for high speed continuous driving on the Autobahn. I know that driving in lower gears here in the States to "simulate" more continuous higher revs is not a perfect comparison as the higher speed would bring more cooling.
On the other side the Corvette should be able to run for an hour or two at 140 to 180 mls/h.
Corvette dealer/tech says no problem at all - no bad experiences - but I don't think most customers will run those speeds here.
Should I add the Z06 Oil cooler? Other ideas?
Old Sep 5, 2011 | 09:26 PM
TripleAstyle123's Avatar
TripleAstyle123
Whats your oil temp cruising at 70MPH in sixth gear?
Old Sep 5, 2011 | 10:21 PM
MPZ06's Avatar
MPZ06
It's 225 - 230.
Old Sep 5, 2011 | 10:27 PM
hangtime204's Avatar
hangtime204
280? That's a little too warm. Normal to hot temps for me are about 220-240 in my 08. What oil are you using?
Old Sep 5, 2011 | 10:37 PM
MPZ06's Avatar
MPZ06
Oil is Mobil 1 5W30. Do you have the Z51? Had a 08 Z51, too - seemed to run cooler than Grand Sport. Not sure if Grand Sport has continued the add Oil Cooler.
Checked the shop manual, but did not get a clear answer. Had a 2005 911 Carrera in Germany with auto trans, never went above 270 even after 2 hrs at 6000 rpm.
ZO6 seems to run much cooler. Wonder if they have really prepared LS3 for endurance speed...
Old Sep 5, 2011 | 11:02 PM
fnsblum's Avatar
fnsblum
280 is too hot. Later! Frank
Old Sep 6, 2011 | 01:58 AM
HeavyRightFooT's Avatar
HeavyRightFooT
The car has a pretty good oil monitoring system, it will also adjust the oil life status based on the actual condition of the oil, the way you drive the car, the temperatures it operates at ... if it is not telling you its too hot, then maybe it isnt.
its in the user manual if I recall well ...
Now that said, you gotta be driving that thing very seriously to get 280f on the street !! ... I barely get that on the track.
You are in germany comuting on the autobahn or what ?
Cheers
Old Sep 6, 2011 | 08:10 AM
MPZ06's Avatar
MPZ06
Cheers
Yeah, I will probably commuting there, and have some nice frequent trips on the autobahn - I'm using the car as a daily driver.
True, there is no overheating message yet - am worried about the potential as I don't have ("can't create") the same conditions here.
Its less about track days than "fast commute" as the car is automatic, no dry sump etc. Nevertheless, running 4500-5000 rpm on highway for 20 minutes and 270 to 280f worries me as those revs (OK in higher gears and more air pressure due to higher speed )will be normal on "autobahn mode".
Take care
Old Sep 6, 2011 | 11:24 AM
Bill Suttie's Avatar
Bill Suttie
There is two pieces of missing data. Ambient temps and miles on the engine? I assume since it is a grand sport it has a dry sump engine oil system?
Old Sep 6, 2011 | 12:01 PM
Ragtop 99's Avatar
Ragtop 99
OP:
what are you coolant temps when the oil is at 260* and above?
I think the GS automatics do not get the dry sump.
Old Sep 6, 2011 | 01:26 PM
fred_S's Avatar
fred_S
280 is way to high, I don't get that during a track day with ambient temperatures of 95. Trust me, I live near the German unlimited autobahn, during a WOT run oil temps reach 266 with ease because of the high revs. (ambient temp of 80)
Fred
Old Sep 6, 2011 | 01:47 PM
MPZ06's Avatar
MPZ06
Ambient temps 70-85.
No dry sump (auto).
Miles 5000.
I was in Sebring this year and could talk to Tadge Juchter, my question was why Grand Sport automatics are excluded from Dry Sump.
Answer was that anyhow the automatic would be the limiting factor and 270f wouldn't be a problem (But I believe this was said more in respect to turns/g's than continuous high speeds).
My concern is, that the temperature will continue to rise beyond 280f as 280 was "easily" reached after "normal" driving at 75 mls in 6th for a longer time and then going for only 15-20 minutes at 75 mls/h in 3rd and 4th.
I'm aware that this does not correspond exactly to driving 150 mls/h in 5th or 6th for 20 min as you have more cooling at 150 mls/h.
But it can be compared to fast driving on roads where you are in lower gears due to turns.
I'm getting the impression that GM has "arbitrarily" taken the decision to have rather limited sport orientated specs with automatic Corvettes.
Don't take me wrong - I love Corvettes, "left" Porsche for Corvette and will stay with Corvette.
Old Sep 6, 2011 | 02:11 PM
Bill Suttie
No dry sump (auto).
Miles 5000.
280 F is hot but not bad if it was a stabilized temperature at 90 to 100 F ambient. You may want to add the Z06 EOC to the car.
Old Sep 6, 2011 | 02:19 PM
Ragtop 99's Avatar
Ragtop 99
I'd be concerned about tranny temps too. Have you monitored them?
Old Sep 6, 2011 | 02:23 PM
MPZ06's Avatar
MPZ06
Tranny's Ok - 215.
Old Sep 6, 2011 | 02:28 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
An oil engineer posted here that for 5W-30 oil, you want oil temps of 190'F to 260'F for full throttle use. The Service Manual says our 2009 does not turn the radiator fan to High until the oil temp hits 302'F.
Based on that, I'd be ok if oil stayed below 260'F on the autobahn. If necessary, you could add the Z51 or Z06 oil cooler.
I've noticed that running high rpm at moderate throttle, raises the oil temp a lot more than I would expect, compared to what happens under "normal" high power conditions.
I'm guessing you won't need that extra oil cooler, let us know how it all works out for you.
EDIT: Corrected typo on autobahn oil temp. Originally I said 280', should have said 260'.
Old Sep 6, 2011 | 02:48 PM
MPZ06's Avatar
MPZ06
Thanks for all your answers and help!
Hope I can extend my stay here in the US.
Take care
Mirko
To Oil temp LS3
Old Sep 6, 2011 | 02:55 PM
theofel's Avatar
theofel
St. Jude Donor '10-'13
Tranny's Ok - 215.
215 is not OK when cruising. Much too hot! Add a tranny cooler and it will be 160 at cruise speed. Heat is what kills the A6 tranny.
Old Sep 6, 2011 | 03:03 PM
Bill Suttie
Originally Posted by theofel
215 is not OK when cruising. Much to hot! Add a tranny cooler and it will be 160 at cruise speed. Heat is what kills the A6 tranny.
215 F trans sump temp IS NOT HOT.
Old Sep 6, 2011 | 03:38 PM
Gearhead Jim
St. Jude Donor '13
On our 2009, and probably all the A6 cars, the high temp warning for the trans comes at 270', and they recommend getting it below 230'. Based on that, 215 is acceptable.
However, my car usually runs below 200' in most highway use, the highest I've seen was 219' stuck in traffic for an hour on a hot day.
If I was seeing 215' on a daily basis, I would want to reduce that and would probably install an extra cooler. But if it only happens occasionally, that shouldn't be a big problem.
Most cars don't have a trans temp gage at all, I shudder to think at some of the temps I must have experienced in previous cars.
