Doors hitting fender
Old Sep 6, 2011 | 11:16 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Default Doors hitting fender
2007 convertible when opening the door it will try to hit the edge of the fender where the gap should be. It has happened twice on the driver's side and once on the passenger side. It's not always happening. Could the hinges be loose or the fenders? It's an IPC replica so I don't want the atomic orange paint chipped or scratched. Any idea what the issue is? I thought there was a thread about this but could not find it doing a search. Thanks.
Old Sep 7, 2011 | 01:28 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My 06 Coupe did it on the the passenger side on the Connecticut (hottest of days)
If you want to fix it,,, you will have to re align the fender (not a very difficult job)
BC
Old Sep 7, 2011 | 09:52 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
BC
Yep. Same here. Mine did it from the factory, but when I put on the Wide Body kit the body shop aligned it better and it no longer does it.
Old Sep 7, 2011 | 09:59 AM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
there is 2 screws to pull the fender out a small amount, under the rear of fender and one in the center of fender by door, this one you will have to drop the rear inner fender cover to get at it.
Old Sep 7, 2011 | 10:49 AM
LEAVINU's Avatar
LEAVINU
Yep, both 7mm screws.
Old Sep 7, 2011 | 10:53 AM
el es tu's Avatar
el es tu
advice - do the minimal.
sometimes you can spend more time going back and forth just to eek out that last mm and then somehow end up worse than you started.
oh and an extra set of hands makes the process MUCH easier.
Old Sep 7, 2011 | 04:58 PM
ScaryFast's Avatar
ScaryFast
Mine just started to do this as well. Very irritating, it has already chipped the paint on the edge of the passenger door. Irritating.
Time to realign the fender when I put in the new lowbeams I just got to replace the failed ones...the car is suddenly falling apart.
Old Sep 7, 2011 | 11:26 PM
Tally Ho's Avatar
Tally Ho
Thanks everyone. I figured as much. Time to get busy.
Old Sep 8, 2011 | 11:13 PM
HAD2HAV2's Avatar
HAD2HAV2
Funny how a couple of 7mm screws can mess up body panels on a world class sports car. I love them any way. I would replace these screws with new ones by following pmj341's instructions. The screw maybe worn because it was not tight to begin with. Not a hard job, I've done it, passenger side.
Old Sep 9, 2011 | 08:02 AM
armybyrd's Avatar
armybyrd
The day I brought my '11 C6 home I had her parked on a slope of our driveway and the drivers door hit the fender. Took the car back the next day and they adjusted the fender. Kinda interesting to hear that others have had this problem.
Old Sep 10, 2011 | 01:07 AM
Tin Star's Avatar
Tin Star
From: Amelia Island,FL ______ or DFW _________ Sold my 05 MS Coupe ____ bought 08 Vert Blk/JSB, 3LT, F55
My 08 does it when it sits in the sun and heats up. Can we get a detailed explanation and/or pictures?
To Doors hitting fender
