RCDLR (remote control door lock receiver)
Old Sep 10, 2011 | 03:43 PM
05torch's Avatar
05torch
Default RCDLR (remote control door lock receiver)
I've read plenty of older threads and it appears that my RCDLR is not functioning properly and my question is - if I replace it myself, the dealer would still need to initialize or program it - right? If so then I might as well have a flatbed take the 05 C6 to the dealer and let them troubleshoot. This pains me since I've never had to resort to towing a vehicle and relying on a dealer to repair it.
Just in case I'm missing something, here are the symptoms:
* Replaced fob batteries (Energizer) in both even though were replaced last year - neither work
* Optima Yellow top installed last year, on charger the whole time, and passed a load test
* Burglar alarm LED flashes normally
* fob lock/unlock/trunk buttons do nothing
* Squeeze driver's door pad and get a clicking sound, but door doesn't open, the LED doesn't light, and the window has dropped about 3 inches and stays there
* Squeeze passenger door pad and window indexes down/up, LED flashes on, but door doesn't open
* Cannot open or unlock doors from inside
* ACC button doesn't activate
* Red light (RAP) will light
* Interior, trunk, and hood lights come on - horn works
* Pushing radio button causes clock time to be displayed
* Start button is illuminated after the driver's door is closed, but car doesn't turn over - hear clicking sounds
* fob in glovebox transmitter pocket doesn't work
* Tried matching fob to car - Opened trunk and turned key 5 times within 5 seconds, but no DIC display
Old Sep 10, 2011 | 07:02 PM
tjwong's Avatar
tjwong
Sounds more like a battery issue or a ground. First thing I would do is to get someone with a scan tool. I have had the earlier cars do some real weird things if a battery is disconnected or drained. I have had to go in with a Tech2 scan tool to clear all know DTCs from all the devices in the car, these would include the RCDLR, BCM, PCM, door, radio and other modules that are in the cars CAN network.
Old Sep 10, 2011 | 09:27 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
I'd have to go with the battery also. Optimas are notorious for being crap batteries, but they have a great warranty. A battery can "seem" fine, but if it has a bad cell it will cause all kinds of electrical problems. Try a battery out of another car and see if it still has the same issues.
Old May 22, 2019 | 03:19 PM
King Ace's Avatar
King Ace
1st Gear
Did you ever change out you RCDLR? Did the dealer have to reprogram the receiver?
Old May 22, 2019 | 03:32 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Rcdlr
. 8 year old thread. FYI.
Old May 24, 2019 | 08:23 PM
Dano523's Avatar
Dano523
On some cars that see rough road use, have seen such take out the RCDLR. Same with water damage to the RCDLR boards, and even with a few on board relays that have worn out.
When the RCDLR is flashed, it makes sure that the GM security hand shake code is all the same with all the needed modules on the car. So short of a board that can no be repaired to solve it problems (since it will maintain the security code number as it being repaired), best to have the new RCDLR firmware flashed to the car.
Also, before replacing a RCDLR, pull codes to make dam sure the module is the problem. Hence has seen some RCRLR (and other connectors) so corroded, that its the corrosion on the connector pins the problem alone instead.
Old Feb 3, 2026 | 03:44 PM
DRM5150's Avatar
DRM5150
4th Gear
I had my 2005 RCDLR go bad. Can't be repaired. Can't get a replacement unless you can find one on the secondary market. BE SURE YOU HAVE THE SAME PART NUMBER, I believe it's an 8 digit number. Then the dealer will have to program it. Just found my part last week, dealer repaired it this week. Appears to work fine. Any question, let me know.
To RCDLR (remote control door lock receiver)
