starter motor install
Old Sep 13, 2011 | 03:50 PM
clakian's Avatar
clakian
Default starter motor install
does anyone have the instructions on how to install a 2009 c6 starter motor?
thank you
chris
Old Sep 13, 2011 | 04:32 PM
SpecialSause's Avatar
SpecialSause
drop the passanger side header, undo the two bolts that mount the starter, plus wires going to the starter. Remember where they go and put the new one in its place then put the header back on.. at least that is what i had to do with my longtubes.. easy 30 min job..
Old Sep 13, 2011 | 04:53 PM
Motorhead-47's Avatar
Motorhead-47
Stating the obvious...Step #1...DISCONNECT THE NEGATIVE BATTERY TERMINAL!
Old Sep 13, 2011 | 05:51 PM
clakian's Avatar
clakian
thank you
Old Sep 14, 2011 | 12:03 AM
glennhl's Avatar
glennhl
I had to take the bolt out that holds the plastic shim in front of the starter. Otherwise the starter was stuck and would not pull out.
To starter motor install
