LG Header Question
Old Sep 14, 2011 | 12:58 PM
wiggins82abn's Avatar
wiggins82abn
Default LG Header Question
What is the big difference between the LG Street Series and LG Pro headers? (Hp/Tq and Powerband differences)
Does anyone have any graphs to show the comparison?
Looking to purchase one or the other as my next mod.
Old Sep 14, 2011 | 01:02 PM
Don 79 TA's Avatar
Don 79 TA
i just put in the LG streets
i like em on my wifes 05 auto
supper easy to install
nice added sound to the car too
in a nutshell, one is more for lower end torque use (streets) where the pros is more upper higher HP concern
at least that is my interpretation
give LG a call, they will give you the 411
Old Sep 14, 2011 | 01:03 PM
wiggins82abn
Mods are:
FAST 102 LSX-R Intake Manifold, FAST Fuel Rails, BBK CAI, Katech Powder Coated Valve Covers, Katech Coil Relocation Kit, MSD Wires, American Thunder Exhaust, DMH Cutouts,
FloydSummerOf68's Avatar
FloydSummerOf68
On a stock internals motor the SLIGHT difference in hp/tq that you might experience wouldn't outweight the difference. If you plan on going to a big heads/cam setup there might be a couple more horsepower to be found.
LG said before that the PROs were only worth 2-4hp more than streets above 5500rpms on a mostly stock car.
I'd stick with the street series for sure in your case.
Old Sep 14, 2011 | 01:07 PM
wiggins82abn
Thanks for the quick responses and info.
I don't think I could justify the extra $$ for a 2-4hp difference.
Old Sep 14, 2011 | 01:53 PM
FloydSummerOf68
Definitely not.
I believe they start to recommend the Pro's as you approach 500rwhp
Old Sep 14, 2011 | 02:28 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
This might help explain it...
All you ever wanted to know about LG Headers
Old Sep 14, 2011 | 03:10 PM
FloydSummerOf68
Hm...I don't think that actually answered anything that the OP was asking.
You guys have done back to back longtube tests before. Surely you have a basic configuration (~450rwhp) with dyno graph showing the difference between Pros and Streets?
Old Sep 14, 2011 | 04:16 PM
Former Vendor
Covers a good bit about the physical differences in the systems.
Now if you are talking about HP....
I have Street Series packages on 500 rwhp cars, would they be better going to the larger systems, sure they would.
500 RWHP Street Series
Generally speaking 450-470 rwhp is about where I cut it off for the Street Series and you start to see a bigger difference.
If you are talking about a bolt on car, no other changes there is roughly a 4-8 rwhp difference in them and most of that is above 5000 RPM due to the merge collector on the Super Pro's.
Talking with the C6, I generally do not go 1 7/8" (Super Pro only), unless we are talking about a radical combination that is going to see a lot of high RPM use or supercharged applications.
Old Sep 14, 2011 | 04:36 PM
FloydSummerOf68
...and I believe we are
So do you have any before/after graphs to show the 4-8rwhp gain?
8 additional rwhp on a bolton car is a ridiculous amount. If there's any proof of this on back to back dyno's I'll be looking for a set of LG Pro's to replace my current longtubes.
Old Sep 14, 2011 | 05:06 PM
Former Vendor
For what you have listed as far as modifications go, I do not see the difference on doing the Super Pro's over the Street Series.
Old Sep 14, 2011 | 05:10 PM
FloydSummerOf68
So is that a "no" to having any graphs showing what you just said?
Old Sep 14, 2011 | 05:32 PM
Former Vendor
Coming shortly....remember tests vary vs the car that is why I say that range..
Old Sep 14, 2011 | 05:34 PM
Former Vendor
No it isn't....different question..
Here is your graph.....
Car tested 2006 LS2 Corvette
M6 Z51
Stock air box, stock mufflers.
LG Street Series no cat vs LG SuperPro no cat
No changes to the tune between, but these are tuned numbers.
As I said, results are going to vary. On this test it was almost 4hp difference between the two. Notice torque change as well.
Old Sep 14, 2011 | 07:10 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
^^^^ good info!
Old Sep 14, 2011 | 10:00 PM
FloydSummerOf68
M6 Z51
Very cool info...thanks for posting it up
I'd still like to see a graph showing up to 8rwhp difference though.
Old Sep 14, 2011 | 10:19 PM
NYC6's Avatar
NYC6
On my stock car some years ago, I went with the Pro's. I knew the car wouldnt stay stock for long. Didnt want to regret getting the headers that wont perform as well as the power got turned up.
I do however, regret not going with the 1 7/8 variety. I dont know how much hp it cost me though.
To LG Header Question
Old Sep 15, 2011 | 04:26 AM
wiggins82abn
M6 Z51
Thanks Anthony. You pretty much answered all of my question. It is much appreciated. Thanks for taking the time.
Old Sep 15, 2011 | 08:30 AM
FloydSummerOf68
Probably close to nothing.
Old Sep 15, 2011 | 10:36 AM
Former Vendor
LS2 or LS3 car?
From testing here, even on larger cam'd cars going to the 1 7/8" on one of those cars would cost it 10-15 ft-lbs of torque then the lines will match up around 3500-3700 RPM and follow close to each other and the 1 7/8" would start to pick up a slight bit of HP above 5500 RPM but we are not talking much more than 2-4 hp at that point on a car making 470 rwhp on a LS3 car.
I'll see today if I can find the graphs of it. I didn't do them on the same day but it was the same car we did it on, and roughly 5-6 pulls between the two sets.
