User Experience With Tire Rack Tpms Tool needed
I'd like to hear from anyone who has personally used this and better yet owns one and can confirm it works as well as the Gm dealers unit. Reading the instructions from Tire Rack they reference three models. VT5 a VT10 and a VT15. The unit pictured is an model VT5. Please try and state your model.
Thanks very much. I'm now driving my C6 waiting for the DIC to display " flat tire reduced power and speed".
Please chime in [ not intended as a pun }.
http://forums.corvetteforum.com/1575521581-post3.html
Any one else with the Vat or any other programmer suggestions?
Bill
Bill
I responded to the other thread before I saw this one.However, having the tool has the ability to verify if the sensor has malfunctioned. Simply reprogram the sensors, but change the order of the sequence in which you acquire the signal. The car doesn't know where the wheels are, just the order you got the signals. If the LF (the suspect sensor) is sequenced last instead of first, you will get a good reading for the LF on the DIC and a flat showing somewhere else. The correct sequence is LF, RF, RR, LR. If you change the sequence to RF, RR, LR, LF, then the DIC will show the flat tire on the RF, because it's the first one on your revised sequence. That will confirm the sensor in the LF tire is bad rather than any issue of the car's receiver.
Of course, do a correct sequence reprogram after the test, so all the other sensors show the correct location. You will also need to reprogram again after installing a new sensor.
In the meantime, keep the tire gauge handy.
All the more reason I'd like advice on which non Gm tpms programmer to purchase. Have a digital tire gauge in all my vehicles.
And thanks Bill we like to do weekend road trips and now knowing speed won't be limited is "worth it's weight in gold" [well almost!].
