Battery connected backwards on C6. Where to start?
Old 09-24-2011, 11:21 PM
mike100
mike100's Avatar
Kudos for following up. I wish more people would.
Lee Cromwell (05-17-2023)
Old 09-24-2011, 11:59 PM
TTZ06VETTE
TTZ06VETTE's Avatar
Good job troubleshooting and fixing the problem yourself. Now you can once again sleep at night.
Just went through the same thing tracing out the wiring on my methanol injection system that suddenly went dead. Ended up being a broken wire tied into the fuel pump circuit. Could have lost a piston from that one.
Old 09-25-2011, 09:12 AM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
These types of threads are so important, and Google picks them up.
A very similar thread got me out of a jam when jumper cables were hooked up backwards on my mom's PT Cruiser....in that case there's a main fuse that blows and once replaced it's good to go.
Chevydriver123 Thanks for posting!
Old 07-12-2018, 06:51 PM
Tom Philbin
1st Gear
Tom Philbin's Avatar
I also just had a Tech cross the battery cables on my 1979 L82 Corvette. I plan on trying a new battery first. Pre ECM and all stock except for a Clifford alarm. Any tips would be appreciated. Losing sleep in Chicago.
Old 07-13-2018, 11:33 AM
ptroxx
ptroxx's Avatar
Location: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
you may want to post a new thread in the C3 section.
Old 07-13-2018, 12:09 PM
Kenny94945
Kenny94945's Avatar
Thanks for the follow up!
Good post to follow if a battery cable mishap ever happens.
Old 07-13-2018, 12:18 PM
Black 03 Z06
Black 03 Z06's Avatar
Wow a frustrating and expensive momentary lapse in attention. Sorry it happened.
Like others have said great that you followed up to a conclusion, so many people do not and we are left wondering what happened.
Hope it is all sorted for you now.
Old 07-14-2018, 08:56 PM
Boomer111
Boomer111's Avatar
If the Diodes worked properly they should save components. Granted some traces could be burnt.
Old 11-24-2020, 09:57 AM
chevy406
chevy406's Avatar
This thread was very helpful when I recently touched my battery leads backwards on my 2008 Z06. Here I am at 53 years old doing something so careless as connect a battery backwards. After unbolting my passenger side header I didn't see any issue with the connections; alternator looked ok; all fuses checked out. I had to recharge my battery overnight, and then amazingly it started and ran just fine. Only issue was no sound from the radio. Because of this thread, I pulled the Bose amp out and found the damaged wire (more like foil really). A simple solder repair got it fixed. Just have to remove 4 bolts holding the amp in; 2 harness connections; and 8 torx bolts holding the amp together.
Thanks again to the members of CF for the help. Here are a couple pictures for my contribution.
Old 11-26-2020, 05:58 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Excellent work!! Probably saved you a thousand or so dollars by troubleshooting/ repairing it your self.
BC
chevy406 (12-08-2020)
Old 05-17-2023, 05:48 AM
RLW2019
3rd Gear
RLW2019's Avatar
Default Same Problem
I bought a new battery for my C6 and let them install it, a free service, what could go wrong, right? The employee hooked it up backwards, momentarily. It sparked, I didn’t try to turn ignition on till corrected. It started, but no HVAC fan and no stereo/Nav, it’s being repaired at their expense. After reading this I’m not terribly worried about a lifetime of electrical gremlins in my future that the parts store would probably not be eager to accept responsibility for. They owned up to their mistake without hesitation thus far, keeping my fingers crossed.
Old 05-17-2023, 09:47 AM
Chatman
Chatman's Avatar
Would this be covered by your home owners insurance? Something like cutting down a tree and it falls on your car.
Old 05-19-2023, 07:19 AM
  #33
RLW2019
3rd Gear
RLW2019's Avatar
No, they changed the battery in the parking lot of the auto parts store. Normally I would take the battery home and swap it out myself, then take the old (core) back to the parts store. But I was the only customer in the store so they offered to change it for me without any waiting, and save me a return trip w/the core.
Quick Reply: Battery connected backwards on C6. Where to start?
