Jacking locations?
Old Oct 3, 2011 | 02:48 PM
05blkbeauty's Avatar
05blkbeauty
Default Jacking locations?
Relatively new Vette owner- couldn't tell by owner manual where to put jack- I've seen oblong holes in frame rails, and the 'jack pads' that aftermarket sells- are these oblong holes where you are suppose to put the floor jack?
Old Oct 3, 2011 | 04:25 PM
ebf2k's Avatar
ebf2k
St. Jude Donor '12-'13-14
check out the FAQ:
http://forums.corvetteforum.com/c6-z...ons-faq-3.html
Old Oct 3, 2011 | 05:25 PM
05blkbeauty
Thanks for the detailed info- but are the 'black circles' on the rockers also safe if you have a pad or are the red locations the only safe way? Also, the jack adapter is really neat- where do you get those?
Old Oct 3, 2011 | 06:49 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
The black circles are OK to jack also, but you need some jacking pucks to put in the holes at those locations which your jack pad can make contact with. Otherwise your jack pad can contact the rockers directly and crack them. Several vendors carry the pucks, I got mine from eliteengineeringusa.com.
Old Oct 4, 2011 | 08:11 AM
el es tu's Avatar
el es tu
that and in the cases where the jack fits without a puck, you can scuff the frame sealer/ paint with the metal contact
Old Oct 4, 2011 | 09:15 AM
05blkbeauty
This forum is fantastic! Thanks to all who helped!
Old Oct 4, 2011 | 05:09 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Just one thought-
If you are jacking on the front crossmember behind the oil pan, it would be easy to also end up jacking on the pan itself. That's a no-no.
Old Oct 4, 2011 | 05:26 PM
Bill Dearborn's Avatar
Bill Dearborn
I jack at the shipping slots. As for screwing up the paint using a jack by itself the jacking pucks move around as well and can scratch the frame paint just as easily as the jack. You can also use a small piece of 2x4 that is cut to fit in the hole in the rocker and that will give more load bearing surface than the puck will and will probably protect the paint. I place my jackstands under the cross members where the so called preferred jacking points are located. Have owned C5s and C6 for 14+ years and have never used one of those cross braces. You don't need them. The direction in the shop manual tells you to make sure the jack or jackstand bridges between the front and rear of the cross member not across the cross member. The front of the front cross member is like an inverted U and you have to bridge across the inverted U which is about the width of the top of a jack stand. Same goes for the rear of the rear cross member. Some people get too **** about things and overdo what is required.
Bill
Old Oct 4, 2011 | 09:09 PM
Gearhead Jim
St. Jude Donor '13
Bill
Looking in my 2009 Service Manual pp 1-26 & 1-27:
First, the drawings are for a C5, so I'm suspicious already.
Next, the shaded area for approved lifting/jacking on the crossmember just in front of the oil pan does show the whole thing is acceptable if you pad the jack and span at least 2 ribs. Good.
But, the drawing for the "front-front" crossmember has the acceptable shaded area only out at the ends, not the center.
Finally, the drawing for the rear crossmember shows spanning 2 ribs only out at the end, and the shaded area is only out at the end.
In summary, my Service Manual shows it is acceptable to lift all the way across the crossmember by the oil pan, just so long as you pad the jack and span at least 2 ribs (and don't hit the pan as things flex!). But the Manual shows that the front-front crossmember, and rear crossmember, should only be lifted at the ends.
I'm not saying that simply using a padded jack in the center of any crossmember will damage the car, but GM does not approve those locations. Any damage might be difficult for most of us to detect, and pretty expensive to repair.
Old Oct 5, 2011 | 05:29 AM
CO Lightfoot's Avatar
CO Lightfoot
See "Jack" on Bugman's website: http://www.bugmanweb.com/c6/c6index.html
Old Oct 5, 2011 | 03:34 PM
Gearhead Jim
St. Jude Donor '13
That's a good "How To Do It", but he's jacking both the front and the rear in locations which GM does not approve. Will that cause damage? Maybe not, even probably not. But I don't want to take that chance. Others may feel free to disagree.
Old Oct 5, 2011 | 03:55 PM
Shifter6's Avatar
Shifter6
I use the "bugman" center jacking points. I just use a 8" 4x4 (laying down) against the front and rear crossmember (spanning multiple ribs) and place the jack in the center. I know it does not evenly distrubute the load, the 4x4 is there to protect the crossmember. I have never had any problems. But I have had the benefit of not having to buy load distributors or special jacks.
I have searched on this extensively and found others, including bugman, who do it this way. I have yet to hear of any damage caused by using this method.
And no, I am not a GM engineer, but I do own my C6 and am willing to risk it by using this method.
Old Oct 5, 2011 | 04:12 PM
Bill Dearborn
All perfectly true. However, there is nothing preventing you from jacking at one end of the cross member. You don't need to bridge between the two ends.
The difference between the C5 and C6 cross members is minimal and doesn't require a different method of jacking the vehicle. That is why they use the info from the previous SMs. No need to change it.
Bill
Old Oct 5, 2011 | 07:54 PM
CO Lightfoot
Lots of ways to raise a C6. But you don't say WHY you want to jack it. That is, depending on the job, some jacking methods are overkill.
For instance, I use wood planks for an oil change:
Some folks report doing an oil change without wood planks... just angle the front wheel and you can reach the drain plug & filter (if your arms are long enough).
Or to remove just one wheel, wood planks provide extra clearance so I can use an ordinary jack -- although a low-profile jack might be worth the $$$ for the convenience.
Just be sure your jacking pad does NOT contact the easily-damaged plastic rocker panels. Jacking pucks are handy for that purpose. Lots of nice pucks out there... I got hockey pucks from amazon for $1/ea that work just fine.
To Jacking locations?
