How do i flush my radiator
Old Oct 9, 2011 | 02:09 PM
PRicanC6Xpress's Avatar
PRicanC6Xpress
From: From: Brooklyn Kiddo, Live in Wantagh, Long Island NY....... New York
Default How do i flush my radiator
I'm definatetly not a mechanic, as I read through these threads most of you guys on this forum. Know as much as a mechanic or most of you are mechanics. I'm new to this sport of having a corvette and would like to flush my radiator. Actually my 05' c6 is leaking anti freeze, at a slow rate. I want to take out the radiator inspect it and have it flushed can any one of you guys help me out............. Thanx
Old Oct 9, 2011 | 04:41 PM
Paratrooper307's Avatar
Paratrooper307
Before removing the radiator, see if you can isolate the source of the leak. In many cases, its a bad hose or a loose clamp. Sometimes a water pump will leak also. If there are no visible leaks, but you are using coolant, you may be dealing with a bad heater core or head gasket.
As for flushing the system, there are several ways to it. If the fluid just is due to be changed and isn't all gunked up, you can just drain the fluid out of the radiator (drain **** is on the passenger side) and replace it with new, running the engine and heater and adding fluid as necessary as air pockets are eliminated. If you want to be really thorough, you can also drain the coolant out of the block and heater core.
Power flushes as advertised by some shops are generally not necessary unless your system is really dirty, and in many cases you can flush out the sediment yourself with a garden hose.
If you do find that you have to remove the radiator, it is a fairly simple job after removing the intake, upper and lower mounts and the fan assembly.
Old Oct 9, 2011 | 10:07 PM
Ragtop 99's Avatar
Ragtop 99
a couple helpful threads:
http://forums.corvetteforum.com/c6-t...t-on-a-c6.html
http://forums.corvetteforum.com/c6-t...-diy-page.html
Old Oct 9, 2011 | 10:35 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Before you drain your antifreeze call around and see where you can take it for disposal...none of the parts stores in my area that take used oil would take it. I had a heck of a time getting rid of it. Finally my buddy who is a mechanic took it to work and disposed of it in their recycling system.
Oil is easy to get rid of, antifreeze wasn't for me. I think next time I'll just have it done at the oil change place (not the one that wouldn't take my antifreeze!).
Old Oct 10, 2011 | 07:01 AM
turbod's Avatar
turbod
Used to do my own flushes but it's difficult finding a recycle facility that will take it.
Old Oct 10, 2011 | 10:27 PM
PRicanC6Xpress
Default thnx
I took the car to the corvette shop in Montgomery Ny.... Paul the owner is a decent guy......... Hoping it's not a huge problem. I checked my garage floor last night and there was additional anti-freeze on my floor........... Thanks guys wish me luck.
Old Oct 11, 2011 | 07:54 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Flushing the radiator probably will not address the LEAK. If there is a puddle on the floor, the source should be easy to find. Fix that.
Old Oct 13, 2011 | 10:34 PM
PRicanC6Xpress
Dave you think it can be fixed by a radiator shop..... It's actually for reasons I don't know not leaking now......
Old Oct 14, 2011 | 08:24 AM
davekp78's Avatar
davekp78
I don't understand what you mean. What I'm saying is it won't be fixed by flushing. You need to find the source of the leak.
To How do i flush my radiator
