Service Fuel System message help needed
Old Oct 9, 2011 | 11:03 PM
mfquinn's Avatar
mfquinn
Default Service Fuel System message help needed
Found posts on this issue. Disregard
I have a Service Fuel System message on my DIC and my gas gauge is showing empty on a full tank. The fuel range shows low - dah!
Last edited by mfquinn; Oct 10, 2011 at 05:43 AM. Reason: found a post that answered question
Old Oct 11, 2011 | 02:21 PM
jtgalbraith's Avatar
jtgalbraith
1st Gear
I bought mine in august of this year (2011), a 2005 coupe. After 2 days the check engine light came in, then went away. I figured it was the gas gap not being put on right by Chevy. After another week I got the same warning you did. Turns out there's an issue with the fuel sensors that cause this. Mine is being fixed today. I took home and bought the extended warranty...waited a month, and brought back in. It's a $1400 job!!
Good luck..it doesn't effect anything with the car so you can drive without concern.
