Problems, rear dif hopping
Old Oct 10, 2011 | 05:33 PM
fennerhillpro's Avatar
fennerhillpro
Default Problems, rear dif hopping
I had some clunking and rear end grinding when turning slowly. Today I changed the rear dif fluid and transmission fluid. I have 40k and done several hpde on a 2007 base. While doing the figure 8 noticed more noise and rear end hopping. Seems to be getting worst only happen on slow turns. Any ideas? Could it be an axle problem at a loss
Old Oct 10, 2011 | 06:03 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
what rear diff fluid did you use?
Old Oct 10, 2011 | 06:09 PM
fennerhillpro
I just the fluid I purchase at the dealer. I can go check the bottle
Old Oct 10, 2011 | 06:22 PM
fennerhillpro
The fluid is gm 75w-90 synthetic axle fluid 89021677
Old Oct 10, 2011 | 06:25 PM
Neumonic2002
Hmm, I had mine switched out to the new GM LS diff lube and it fixed all my rear end sounds. I will look up the part number you provided to compare.
Old Oct 10, 2011 | 06:33 PM
Neumonic2002
Just performed a quick search, GM DEXRON LS part # 88862624 is the correct diff fluid for the corvette.
Old Oct 10, 2011 | 06:41 PM
Tikiman12's Avatar
Tikiman12
I would check the u joint on the half shafts, this sounds like what happened to my c4
Old Oct 10, 2011 | 07:20 PM
fennerhillpro
What should I be looking for on the u joint
Old Oct 10, 2011 | 08:06 PM
Tikiman12's Avatar
Tikiman12
The u joint is actually a + shape about the size of the palm of your hand. The ends of the u joints are able to rotate arounds it's center point. If they r broken you'll see a crack all the way around that joint.
This is a u joint.
The shiny heads on all four points might be broken. You might be able to see them if u remove the wheel and drop the suspension full stretch, but most likey you would need to remove the half shaft to see them
Old Oct 10, 2011 | 08:21 PM
Tikiman12's Avatar
Tikiman12
Ok trying to research this, the c6 may not have u joints
Old Oct 10, 2011 | 09:39 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
u-joints, lol
Old Oct 11, 2011 | 12:26 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
That fluid is outdated. It should be superceeded with 88862624. Did you add the additive? If not, that could be the culprit.
__________________
Old Oct 11, 2011 | 12:43 PM
fennerhillpro
No they did not give me an additive what does it look like. I will go back to the dealer and discuss this with them. Do you know when the fluid was replaced?
Old Oct 11, 2011 | 12:55 PM
Supporting Vendor
Part number is 1032358. I think they changed the fluid in late 2007 to early 2008.
Old Oct 11, 2011 | 06:30 PM
fennerhillpro
Called them picking the additive any idea if I need one or 2 bottles of the additive
Old Oct 11, 2011 | 06:36 PM
Supporting Vendor
One bottle should be sufficient.
Old Oct 13, 2011 | 08:14 AM
fennerhillpro
The additive resolved the issue. Thank you
Old Oct 13, 2011 | 10:27 AM
Supporting Vendor
To Problems, rear dif hopping
