2007 z06 clutch problems
Old Oct 15, 2011 | 01:13 AM
traderjoe5386's Avatar
traderjoe5386
Default 2007 z06 clutch problems
Hello im in need of some serious help. I have a 2007 z06 and just installed new factory clutch along with slave cylinder. Also has flywheel resurfaced and only took off 8 thousands. Put it all together and when we were bleeding the clutch pedal got hard as a rock and then blew the seal out of the slave. Took it all back apart again and put the slave back together and tried it again. same thing. Now i know i have the clutch installed right, fluid is all new dot 4. I have tried this several times with the same result. What apperars to be happening is the slave wile bleeding is pushing on the cluth plate but is not returning (pedal wont come back up or very slow return) please any help would be great. This is killing me here and cant find any info on this.
Old Oct 15, 2011 | 07:07 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
no idea, jsut guessing: clutch master? http://forums.corvetteforum.com/sear...rchid=26908033
