I'm hoping I can get a bit of help so I order everything I need.
I just purchased an LS9 cam off a board member, and just doing some research on all the parts I'll need.
My understanding is my 2007 LS2 C6 is a one bolt CAM design. So I understand I'll need a timing set that uses a 3 bolt design.
I'm confused though, from what I'm reading, the 2007 uses a 58X reluctor wheel? Do I need to know anything special when ordering a double roller timing set for a 3 bolt unit for an LS2.
Any help would be appreciated for a parts list in doing ls9 cam on a 2007 LS2.
I am upgrading the valve springs and heads to LS3 heads so that part is covered.
Reason: had worded it really silly
x2 on the Auto Zone pulley remover, it works great.
Is there a reason you chose an LS9 cam? That seems like a lot of effort for the 20-25 Hp you may see. There are numberous cams out there that drive like stock but will make much better power. It would suck to go through all the build just to want more power in the end. Just a thought...
At least it's guaranteed that an LS9 cam will drive stock or even better than stock while providing a solid increase in power throughout.
I guess we'd need more input from the OP as to what he's looking for.
True, but many people end up wanting more after they do a small cam install. There are. And out there that have little or no overlap that drives like stock. My point is that most people who put that much time and effort into a cam may want to consider maximizing the results. It's a lot of work for 20 rwhp when you could put in a cam that makes 40 rwhp and drives the same. Most people who installing are a cam are willing to sacrifice some for the power gains, but you are correct - it's up to the OP to determine his goals.
Two things, its cheap and its GM quality, I wont worry about PVT.
I am concerned though since GM didn't design this cam for a centrifugal blower, so they may have sacrificed a little low end with the cam for top end to make up for the Roots style (top mount) blowers that make enourmous amounts of TQ down low.
BUt it seems to me i'll give it a shot, purchase the edelbrock dual piece timing cover, and if I dont like the results, i can always switch it out without pulling the balancer.
Let me know if you decide you want more, yet still still want to remain stealthy. My sleeper cam will make more power across the board and compliments the LS3 heads well, yet drives like stock with it's negative overlap.
